What are these called?
/ What are these called? #1
raykos
Central Pa.
JD2305
I'm thinking about experimenting with building something for my 3pt. hitch, but when I try to find out if I can buy "toplink side bars",(what I think they are), I can't find anything at Tractor Supply nor Northern Tool; so maybe I'm searching with the wrong name? Does anybody know of a source for these parts?
Thanks,
Ray
/ What are these called? #2
I've never seen them sold as an "item", only as parts of another piece of machinery such as a BushHog.
I run a drawbar with a single arm going straight up to the top link.
I don't usually have the weights hanging off it, but the "T" is a very handy tool. It's on there any time an implement isn't.
And no, the high mounted hook is not going to kill me or make my refrigerator stop running, before anyone comments. :)
/ What are these called? #3
It might be called " the frame comprising two upright supports " and what I would suggest is find a piece of 3 pt. equipment that has the frame you want and then find out the part # and contact the manufacturer and buy it or else you will probably have to fabricate one or have it done. Probably the only source for this kind of part is an OEM .
/ What are these called? #4
I always called it the implements A-frame, But i think its called the
( Coupling Frame )
/ What are these called? #5
They'd be dead simple to fabricate if you have access to some raw material. :)
/ What are these called? #6
Thanks,
Ray
I'm certain those are typically referred to as stabilizer bars/arms
/ What are these called? #7
The reason you can't find them, is I keep the market dried up! That is the first piece I tend to bend everytime I back a bush hog into a bunch of woods that I am trying to clear.
As was mentioned, they are easy to build, but need to be done in pairs so that the holes line up between the two. I would also consider building the more durable version which is a piece of plate kind of shaped like a triangle with the same two bends in it. Thinner material, but it does tend to hold up better.
DONOTDELETE posted a picture of his that has this feature.
http://www.tractorbynet.com/forums/...3709991-howse-box-blade-270249-5-ft-howse.jpg
David from jax
/ What are these called? #9
can you outline the process and cite the materal dimensions and hole sizes?
thanks
/ What are these called? #10
They form the part of an implements 3-pt hitch referred to as the "mast". At least it used to was.;)
/ What are these called? #11
Hole size and hitch dimensions can be found at the bottom of the page here:
http://www.tractorsmart.com/main/Tractor Three Point Lift Types.htm
Or just copy an existing implement.
Use 1/4", 5/16" or 3/8" thick (depending on your application) bar stock 3" wide.
As for process I did 'heat and beat' using a sledge and the edge of a concrete block until both sides lined up nicely :eek: I then tacked the two pieces together and drilled the top link hole so it would line up correctly.
/ What are these called? #12
Thanks,
Ray
Tisco sells an 'A' frame kit that you bolt to your 11-hole cat 1 drawbar... I got one from my dealer for about 20$ a few years ago..
soundguy
/ What are these called? #13
Completely different.. a frames are different from stays and stabilizer bars..
soundguy
/ What are these called? #14
Bush Hog dealers can get them as replacement parts. You may not like the price though. Cutting and drilling the holes is easy if you make your own; bending them is a pain if you don't have a hydraulic press.
/ What are these called? #15
Flat bar, heating torch, vise, hammer and drill. Make your own. You may need to get the measurements off another piece of like type equipment if you dont have anything to go by.
/ What are these called? #16
If you have a log splitter,it makes a dandy press for bends like this. Just need a V cut into a chunk of 4 X 4.
/ What are these called? #17
soundguy
I was thinking, possibly incorrectly so, in context of a drawbar type stabilizer for which I've seen both type designs marketed.
/ What are these called? #18
I for sure wouldn't be torching a set if a real one cost 20$ for the whole deal.
soundguy
/ What are these called? #19
Thanks to all who replied with insights on fabricating the frames...great link for dimentsions too...been looking for that info...
Unfortunately my tractor and implements are in GA and I am wintering in FL..so I can't measure anything...
thanks again...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2019 Forest River R-Pod RP-191 Travel Trailer (A61574)
2019 Forest River...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
Case SV280B (A60462)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
