Z-Michigan
I have a JD 5105 utility tractor, 2006 model, bought new in early 2007. It has been mostly trouble-free and until recently has always started. For the first two years of ownership I used it a lot, but for various reasons I probably used it only about 30 hours in 2009. I used it with no problems in November (weather in 50's), then tried to start it up again about a week ago (January) on a 20-25 degree day. It would start and run for maybe 20-30 seconds at idle, then die. It would die almost immediately if I advanced the throttle. It did this two or three times and then wouldn't start up again, at all. It was still cranking OK. I also tried heating the engine area with a propane radiant heater for close to an hour, and that made no difference. I also added 5 gallons of fuel that was thoroughly treated with anti-gel (Power Service) and this didn't make a difference.
I tried again on a day that was around 34 degrees and it wouldn't start.
I used very little fuel last year and the fuel in it was summer fuel, purchased probably in July. I don't remember adding any anti-gel or winter fuel to it, until after I had trouble starting it last week. My guess is that the un-treated summer diesel gelled, that my fuel filter had some fuel that was still liquid but I used that up in the idle time, and now my fuel lines are full of either air or gelled fuel. The treated fuel in the tank probably has not had a way to get into the fuel lines and filter.
Does my guess sound correct?
Should I just wait for a 40+ day? Will I need to re-prime the fuel system based on my description of what has been done? Any tips are greatly appreciated. I have read the owner's manual on fuel system issues but it doesn't seem to address my problem.
