Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.)
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #21
Did you get them from sales or parts? I was trying to price the guards last night and jd parts was saying that unavailable through parts.
Matt:confused:
Matt:confused:
Sales. When I called the parts department at the dealership and stated what I wanted, they said that a salesman would have to order it because it isn't an actual "part", but more of an accessory. But Parts was still able to write my order down and pass it in the right direction.
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #23
Those light kits have to be ordered through a salesman because they are what's called whole goods. They are accessories instead of parts. I got the front auxilary lights and 2 rear work lights. These are by far in my opinion worth the money if you use your tractor at night. Been very helpful pushing snow.
-Funkster-
-Funkster-
:rolleyes:
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #25
Sorry for trying to explain in more detail.
-Funkster-
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #26
Do the rear lites work with the backhoe on? Are you guys setting these up on there own switches?
Matt
Matt
You may have to mount the rear facing lights in a different location in order for them to not interfere with the operation of a backhoe. Or, you could turn the forward facing lights around, which would be easy and they would allow for a wider light pattern as opposed to the narrow pattern from the rear lights being mounted on the inside of the ROPS. Then if you were to add two permanent rear facing lights to the top of the ROPS you'd have more than an ample amount of rear lighting for backhoe-ing.
All 3 of my lights run off of the 1 factory switch.
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #28
Hi WH401 Could you please tell me if that price was for 2 light kits or 1?
The price i got was double your price. $164 $84 thanks.
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #29
The John deere site says the front and rear light kits is not compatable. Is this true?
/ Aux. forward lighting kit and warning light brush guard install on a 3320 (pics.) #30
Only because there is only on plug...and the factory switch is not big enough to handle a bunch of lights (current draw).
Create a new circuit through a relay, from the battery, add you own switches and add as many as you want;)
New Holland WorkMaster 37 (A53317)
New Holland...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
CFG Industrial MX12RX (A60463)
CFG Industrial...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
