Ball Hitch for K B7800
   / Ball Hitch for K B7800
Thanks for all the replies,info and suggestions,very helpful.
   / Ball Hitch for K B7800 #13
I though a B7800 came with a draw bar?
I put a 2" ball in my stock draw bar, 500# draw bar weight and 3000# trailer weight. Thats on a B2710 basicaly the same tractor.
this would be a perpendicular bar for the item off of e-bay.
   / Ball Hitch for K B7800 #15
I think shine is talking about the stock drawbar that comes with any tractor I have ever seen. Nothing to do with the 3PTH. It is safe and simple. K.I.S.S. is best.
   / Ball Hitch for K B7800 #16
Shine is correct
This drawbar is stock on the B7800.
Drawbar is fully extended in these two pictures.
Please excuse the snowblower is still somewhat attached.
I disconnected one end of the the power take off drive shaft
for picture purposes.
   / Ball Hitch for K B7800 #17
I purchased a Tractor Draw Bar Stabilizer for Category 1 Tractor from Northern Tool. It was on special for $59.99 and a ATV Hitch from Harbor Freight for $15.99. I already had the draw bar and 2" ball. I like the fact that it pulls everything from the center. I looked at a Handi Hitch but did not like the off center ball and clevis. I had to take a side grinder and cut off part of the hook base to get it to slide all the way into the receiver. I have used it to move my 21' bass boat with no problem. I tighten the links to keep it from swaying. All I have to do is back up lift the hitch and take off. I pull all my trailers, ball and pin and use the hook and a strap to pull brush. All I have to do is rotate the hitch for everything. It just stays on the tractor.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200342832_200342832
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=65960
   / Ball Hitch for K B7800 #18
Here's one I made.
The "A" lifts out of the bar allowing the bar to be turned over - so I can have a ball or pin.
The "A" does limit turning angle a little, I should have, as originally planned, drilled two holes out further and made a wider "A". (thought I had enough angle)
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
