Chipper Recommendations for a large PTO chipper
   / Recommendations for a large PTO chipper #1
Verticaltrx
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
We're looking for a larger PTO driven chipper to run on one of our three tractors, a JD 4400 (28 PTO hp), JD 2550 (65 PTO hp) or Kubota M9540 (85 PTO hp). Would like hydraulic feed, and something between 6" to 10" capacity, with a discharge chute, since we will be blowing the chips into a dump truck. Looking to spend less than $10K, but we want something good.
We have an Echo/Bear Cat dealer here, and I've heard good things about their chippers, but I'd like some input from the experts. Any recommendation on chippers to fit any of the aforementioned tractors would be great.
Thanks in advance.
   / Recommendations for a large PTO chipper #2
I am partial to SALSCO since they are made here in CT.
The model 6210XT would fit the bill.
http://www.salsco.com/products/6210XT%20WEB.pdf
Not sure what retail price is on one though.
If you really have $10k to spend, you might be better off finding a good used commercial towable chipper. I have seen lots in my area for less than that price, some that will take up to an 18" tree.
   / Recommendations for a large PTO chipper #3
We have a Salsco 627XT mounted from a Kubuta L4310HST - 35HP PTO.
You should contact them for a dealer and demonstration. Valby is also a good brand.
   / Recommendations for a large PTO chipper #4
Valby and Patu. I've never seen a Salsco, so I can't comment on that brand. Champions don't impress me.
   / Recommendations for a large PTO chipper #5
I have a Valby two stage that will take up to 8" logs. I run it behind two tractors. One has 90 PTO HP and the other has 35 PTO hp.
The 90 hp is prolly a bit much for it so I am careful to not over load the rotor, the 35 hp tractor is just perfect for it as the engin rpms will indicate when I am pushing it too hard.
I have chopped a lot of slash with this unit and it has held up very well over a 10 year period to literally tons of chipping work for me.
I care for a 40 acre apple orchard and log my forest for firewood, chipping all the slash and tops. I work this thing like a rented mule and it has held up quite well.
Thanks for the input, I'll take a look at those. Let me clarify that our budget is $10K max, and I'd much rather spend $5K or less. Has anyone had any experience with the Echo/Bear Cat chippers, good, bad or indifferent?
   / Recommendations for a large PTO chipper #7
BearCat is the only locally available option for me. I have yet to see one as they are out of stock locally at both dealers. I'm hoping to see one in person this w/e. If I get one I'll post my thoughts.
   / Recommendations for a large PTO chipper #8
One vote for not wasting your time with a PTO chipper. No matter how you slice it ( so to speak ) it will not live up to your expectations. Take your ten G's and buy a good used Bandit 90 or 150. Or a Vermeer. Or some brand that people have heard of. This will allow you to do some real work with it, without tying up the tractor. When you are through with it, you can sell it for what you paid, instead of being stuck with a white elephant. My opinion.
   / Recommendations for a large PTO chipper #9
I'm with o2batsea on this one. PTO chippers are fine for the occasional user but large jobs are pushing it (IMHO).
The OP might be better off buying a used stand-alone chipper (you won't buy a new one for 10K) or even renting one for a weekend as required. Good planning can make rental units quite productive (meaning have the trees and branches down and stacked, ready for chipping).
   / Recommendations for a large PTO chipper #10
I can see your logic on that if your chipping needs are not constant or frequent. But I have needed a chipper for 6 years, if I ever get one, I will never be done with it as long as I am living on my lot :)
No doubt the self contained chippers are very capable, but that comes at a price; another engine to maintain, higher initial cost, etc.
There has to be a reasonable middle of the road solution for folks that want to clean up brush, prunings and sapplings that tend to be 4" or less. I think that is where the PTO chipper fits the bill. It's big enough for the task and the cost is bearable. There are members here who have a Salsco or Wallenstine PTO chipper and are pretty happy with them.
Dave.
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
