Turn Minihoe into excavator
/ Turn Minihoe into excavator #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I was wondering if anybody had modified a minihoe to have a large bucket or scoop on it. I would like to be able to reach into a small creek and clear out leaves and trash and perhaps some mud. I did try a 12 inch bucket and it worked, but not really wide enough.
I was thinking about attaching a steel plate across the minihoe bucket. Maybe put some angle iron around the perimeter to strengthen it and hold the stuff in it. Just some wild thoughts at this point.
I have a neighbor who's driveway is sometimes flooded by a ditch backing up. Last time I kinda drove into it with the box scraper and cleared it out. She really needs to raise the driveway, but I expect that is not financially feasible.
/ Turn Minihoe into excavator #2
Dear Bob,
How about angle iron with some pegs to make sort of an overgrown rake that you could drag things out with? That way you wouldn't be overloading the minihoe with too much weight too far out.
Box blades in creeks make me nervous. When I was much younger, I nearly dropped a tractor in a creek trying to do a little clearing and then missing a shift. (Did I mention that lack of a gear shift was a primer motivator in getting a PT?)
It is good of you to look after her.
While it isn't a tractor toy solution, how about a small fence upstream with large wire mesh (4-6") in it to catch the debris upstream of the driveway? They use it a lot around here to keep remote culverts functioning. Just 2-4 T posts, some internal bracing and a short run of fence. Of course, I don't know what your local laws might say about that sort of thing, being a creek and all...
All the best,
Peter
Dear Bob,
All the best,
Peter
Peter, the rake solution might not be bad. I may build that in addition to something else. I wonder how I could easily and neatly connect it to the minihoe bucket. Let's see what others say.
This is really not a creek (even though I called it that), it is kinda a swamp with very low slope paralleling her driveway for about 1000 feet. Then the ditch leading away has very little slope. Her driveway has settled over 25 years. She says it used to be about 2 feet above the creek/swamp.
/ Turn Minihoe into excavator #4
Bob I have this Project going but have not decided how long to make the boom. Any Ideas. Extendable ????
/ Turn Minihoe into excavator #5
Not sure exactly what your looking for but I'll try to describe what I did at one time. I took an old snowplow blade off a garden tractor{36 or 48" can't remember}. I bolted the blade to my BH bucket and it worked great for scraping out nice even wide paths. It worked quite well for clearing weeds and muck around the edge of my pond. I did weld a piece of angle iron to the bottom for strength, which did kill the weight.
/ Turn Minihoe into excavator #6
Stray; that looks like a pretty nice job. I've been thinking about making a clay bucket for my mini excavator. The buckets I have now are a 12"digging and 36"ditch. The little one gets clogged up to easy and the big one is more for just cleaning weeds and lighter stuff. I hate banging the bucket to get the clay out, IMO not good for the machine. I've also thought about installing a chain on the bucket so that when it rotates out it'll help push the clay out{not sure how well it would work}. The clay buckets look like they'd be the cats butt????
Sorry to wonder off of the thread, back to you now BobRip :)
Stray is that designed to be mounted on the minihoe? It looks good, perhaps more than I had in mind. I was hoping that someone had done something, and it looks like you have. How about some more dimensions. Does is directly bolt to the minihoe?
As for length of the boom, I would tend to match the minihoe.
/ Turn Minihoe into excavator #9
Bob... you could use a York Rake. The one I built worked great for cleaning out ditch's and culvert drains. I later modified and shortened it so I could attach it to my Mini Hoe.
I could make a 2 inch receiver that attaches to the minihoe and then make attachments that would also work on my 2 inch receiver quick attach plates (I have 2).
/ Turn Minihoe into excavator #11
I have Lackender's scraper blade for their minihoe. Works pretty well. Slips over the teeth and one bolt holds it on.
Ken
Ken
I could not find the scraper blade on their website. Do you have picture or link?
/ Turn Minihoe into excavator #13
I saw it for $44 but they have no picture of it. Mine is under a couple of feet of snow right now.
Ken
Ken
When the snow melts, how about a picture?
Edit: Oh, you live in NY. So the snow will melt it June?
/ Turn Minihoe into excavator #15
LOL, It has snowed in June. Actually we are getting a spring thaw tonight and tomorrow so there is a chance......
Ken
/ Turn Minihoe into excavator #16
I have a picture of mine but it is at a distance and, well, I am in the photo so we will have to wait for Ken. Basically it is just a cap that goes over the teeth. Angle Iron bent really sharp or what I actuall think is two peices of metal welded in a tight v, end caps that are V and a steel strap that comes off the center which you run a bolt through to hold it in place.
/ Turn Minihoe into excavator #18
Amazing what 50 degree temps and 3 inches of rain can do.
Here are pictures of the Lackender scraper. Had no light out there so had to shoot blind. It would be easy to make the blade deeper or wider if desired. This has worked well for me.
Ken
/ Turn Minihoe into excavator #19
I made a plate similar to what kismolo made. Mine was 1/2" steel attached with bolts running between the teeth, to a piece of angle on the back side, that hooked over the butt end of the teeth.
The problem with a scraper on a mini backhoe, is the machine lacks the weight needed to counter the forces created by such a large surface. Unless you moving very lose material, you end up having to take very soft swipes to prevent the machine from moving all over the place.
As a result, I found a smaller 14" scraper to be much more productive, than a larger one.
Ken
Alright! Thanks Ken. Good pictures. I think I can build that pretty easily. So what is the ratio between the bucket width and the scraper width. I think copying that would be good. It looks like about 1 to 2.
