/ Harbor Freight Tools that don't suck #751
For cutting metal roofing I have tried them all, nothing works as quick, as easy, as clean as a 4" angle grinder with thin cut off wheels, It also wont scratch up the paint or get stuck on humps and bumps. You can just use a straight edge and mark the metal with a sharpie or just clamp the straight edge and follow it. Don't forget gloves and glasses.:D
/ Harbor Freight Tools that don't suck #752
wildwillie, is that the same as a RotoZip? I have a small one with metal blades.
/ Harbor Freight Tools that don't suck #753
I don't know. Maby if you have the right angle attachment ,But I'm sure you can pick one up at HF for under $50.
/ Harbor Freight Tools that don't suck #754
A 4" can typically be had for under $20 if you watch the ads.
4 1/2" are usually about $20 on sale.
/ Harbor Freight Tools that don't suck #755
A nibbler is $30 regular price. Again, that is the proper tool. That's what professionals use. Probably not the HF but it would be great for occasional use. I have one and have used it considerably. Need a good air compressor though.
/ Harbor Freight Tools that don't suck #757
Has anyone used both from HF? which one do you prefer? 4 or 4.5 ? Right now I have a makita 4" for over 17 years. This year the switch is now acting funny and the bearings feels like it's shot. Time for a new one. I want to get a new one first before I take the makita apart to fix in case i screw it up.
/ Harbor Freight Tools that don't suck #759
I've never bought the actual one that HF sells, but I've bought cheaper chinese grinders from other sources. I prefer the 4 1/2". I use it mostly for cutting using a skinny wheel. I burn through grinders pretty fast. The name brand ones don't seem to last any longer than the cheaper ones. I have four right now because I thought my last two cheap ones died. I bought replacements, and the next day the "dead" ones started working again.
/ Harbor Freight Tools that don't suck #760
I would go with the 4 1/2 inch orange HF grinder I have 2 and they work great I got them on sale and I keep a cutting wheel in one and a grinding wheel in the other. I think they have them on sale for $17.99 if you have the coupon.- Harbor Freight Tools - Quality Tools at the Lowest Prices
The only fault I can find is the switch is not a spring loaded switch you have to push it on and push it off.
84'' Skid steer bucket (A61567)
84'' Skid steer...
23105 (A56859)
23105 (A56859)
CAT CB34 (A60462)
CAT CB34 (A60462)
2012 SOUTHERN 130 BBL VACUUM TRAILER (A60736)
2012 SOUTHERN 130...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
Harlo HP6500 (A60462)
