SCD or FD valve
/ SCD or FD valve #1
firefighter9208
Springville, Alabama
2004 Kubota M4800
I am looking at adding a second remote to me Kubota M4800SU. The one remote installed now is a SCD or Self Cancelling Remote. I have to bungee it in place to use the hydraulic log spliiter. I mostly use this remote to run my grapple.
Kubota also offers a FD or Float Type remote.
I want to use a Hydraulic Top Cylinder on one of the remotes and my grapple on the other.
Which one do I need to add???
Chris
/ SCD or FD valve #2
Chris
You want the one that "spring returns to center", I assume that is what they call the SCD.
/ SCD or FD valve
Its is the SCD that returns to center.
The reason that I asked is that I read that it was bad for the system to "hold" the valve open in one position for a long time. I know that the hoses and fittings on my tractor get really hot when I am splitting wood with my 3pt splitter. I'll actually take the bungee off and return the remote to center and let the fluid circulate every few minutes while I am going to get more rounds to split.
Chris
/ SCD or FD valve #4
Chris
It sounds like the better option (and cheaper also) is to add a Power Beyond loop for your splitter and stop using the valve and bungee cord. All you need is a coulple of QD's to do it...
/ SCD or FD valve
Please elaborate. Where would I tap in??? Would I just use 2 short hoses and quick connects or what???
Chris
/ SCD or FD valve #6
Chris
Is you current valve plumbed with hoses or hardlines? Pictures are worth 1000 words...
Also get some of the FEL valve...
In a nutshell, you will put QD's on the PB port of either the remote valve or the FEL valve and plug the splitter inline so it gets constant flow. Most backhoes are plumbed this way also.
Do some searching, this has been covered LOTS of times!
2010 FREIGHTLINER M2 BUCKET TRUCK (A65643)
2010 FREIGHTLINER...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
JOHN DEERE R4023 SELF-PROPELLED SPRAYER (A64277)
JOHN DEERE R4023...
Lowe Pontoon Boat and Trailer (A65579)
Lowe Pontoon Boat...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
