SCD or FD valve
/ SCD or FD valve #1
firefighter9208
Springville, Alabama
2004 Kubota M4800
I am looking at adding a second remote to me Kubota M4800SU. The one remote installed now is a SCD or Self Cancelling Remote. I have to bungee it in place to use the hydraulic log spliiter. I mostly use this remote to run my grapple.
Kubota also offers a FD or Float Type remote.
I want to use a Hydraulic Top Cylinder on one of the remotes and my grapple on the other.
Which one do I need to add???
Chris
/ SCD or FD valve #2
Chris
You want the one that "spring returns to center", I assume that is what they call the SCD.
/ SCD or FD valve
Its is the SCD that returns to center.
The reason that I asked is that I read that it was bad for the system to "hold" the valve open in one position for a long time. I know that the hoses and fittings on my tractor get really hot when I am splitting wood with my 3pt splitter. I'll actually take the bungee off and return the remote to center and let the fluid circulate every few minutes while I am going to get more rounds to split.
Chris
/ SCD or FD valve #4
Chris
It sounds like the better option (and cheaper also) is to add a Power Beyond loop for your splitter and stop using the valve and bungee cord. All you need is a coulple of QD's to do it...
/ SCD or FD valve
Please elaborate. Where would I tap in??? Would I just use 2 short hoses and quick connects or what???
Chris
/ SCD or FD valve #6
Chris
Is you current valve plumbed with hoses or hardlines? Pictures are worth 1000 words...
Also get some of the FEL valve...
In a nutshell, you will put QD's on the PB port of either the remote valve or the FEL valve and plug the splitter inline so it gets constant flow. Most backhoes are plumbed this way also.
Do some searching, this has been covered LOTS of times!
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2021 ROTAIR D185 AIR COMPRESSOR (A65643)
2021 ROTAIR D185...
International 470 Disk Harrow (A66408)
International 470...
