Multi-mount winch advice
/ Multi-mount winch advice #11
I have a Ramsey 9k quick mount winch. I have had it almost ten years now. I did have to put a few new solenoids in it last year. The solenoids were the same part from a Warn winch. This winch is very handy to have and I have used it on several different things. I use it on my trail rig (Suzuki Samurai) and have used it on my last three trucks. I have used it to pull out my 01 Dodge 2500. I keep straps, d-rings and a snatch block in the truck. I also used this winch on my last car trailer, but have not made a mount for my newest trailer yet. JC
/ Multi-mount winch advice #12
I always had somebody along in the group that had a milemarker.
Thanks for supporting my point!!! And you are off my Christmas List!!! ;)
/ Multi-mount winch advice #13
A further point of contention here. RollTideRam has a quality winch that has served him well. A 9K winch will move mountains if properly rigged. For a Multimount setup it's critical that you have a good method to transfer your donor battery power to the winch. A cheap set of jumper cables won't do that.
The best method is a good electrical connection on each vehicle that plugs the winch directly into the battery with heavy wire and quality connections. But that's very expensive, especially if you want the versatility that RollTideRam needs.
The next best method is a heavy wired, lead fastened permanently to the winch with enough cable to reach the battery of the donor vehicle with high quality, strong clamps. Worst part of this is that on some modern vehicles you can't see the battery let alone get a good clamp on a post.
The most used method and poorest is to simply clamp jumper cables on the winch and on the donor battery.
The issue is that his 9K Ramsey probably has a 450 amp draw at it's strongest pull. Very, very few jumper cables will allow that much current to pass thru. For example, if your vehicle had a 450 amp alternator how big would the alternator output cable have to be???
So if you use a multimount you must build a quality cable setup to transfer a possible 450 amp draw from your battery to the winch. Otherwise your 9K winch may become something as small as a 2K winch. The capacity of the winch is directly related to the amperage input.
In a quality setup the winch cost is minimized by the additional installation and support costs. Heavy cables, dual batteries, high output alternator, snatch blocks, tree savers, etc., etc. If I spend my money wisely on the setup and then fasten a cheap winch to it I blew a lot of good money and I'll smoke the cheap winch.
Sorry for the ramble this time.... :)
/ Multi-mount winch advice #14
I had a friend that bought an offbrand winch from a traveling tool sale. It looked nice on his Jeep. He had it for one year before he needed it. Click Click is all it did. I have a picture some where of me pulling out his jeep on 38's with my Samurai. JC
/ Multi-mount winch advice #15
I would agree on the cheap winch is a expensive headache. On mine I have 00-2wire? its about as thick as your thumb. The electic place I purchased it from said would handle 600 amps @ 30' which I only have 18' of power cable on it and have plugins on the one truck and use battery clamps on other trucks or use a extra battery then hook the jumpers up to the battery. On my gooseneck I have the same hook up which works well. I have been able to winch out of most of my problems(on small under 20K equipment) using doubler blocks and chains. For the big headaches I call in the big boys.
/ Multi-mount winch advice #16
I am looking for a multi-mount winch. I have looked at the Warm system and there is a mile marker sytem too I have noticed. I want to be able to use it on my truck (front and back) and also my tractor if needed. My truck is a crew cab diesel so it is heavey. A lot of the multi mounts are rated for 9500# for the first spool of wire on the drum and then down from there. I dont expect to be using it to pull my truck through a mud bog, just vehicle recovery from snow and so forth.
Will a multi mount work for me? Any suggestions for other brands? I expect to rarely use it, how about an "off" brand? Thanks, -Keith
Your rig is very heavy. If it gets really stuck an 8000lb winch is not going to do it. For a full size truck at least 12000 lb winch minimum. If you can, go hydraulic... no batteries / charging system concerns etc.... The portability of electric is nice as well. I went through the same trials and tribulations when buying a winch to recover a stuck skidsteer on my property. I settled on a RECON 17500 7HP electric winch, purchased at auction on Ebay for $480 if my memory serves me correctly. The portability and ready out of the box aspects of a DC unit outweighed the duty cycle of a hydraulic unit for me (not to mention the cost).
Recon Accessories: Products
One fair warning. This thing is muy grande. It will not fit on a standard receiver mount (bolt hole spacing the the same, but the overall size interferes. I have attached a picture of mine on a receiver mount. I used a stock receiver mount and flipped it upside down and popped in some steel spacers. I was in a hurry, with a vehicle to recover and have yet to make a proper mounting setup. It quickly yanked a 8500 lb skidsteer up a 45 degree slope and paid for itself.
After much research I realized that most of the big companies are not using re-branded Chinese made winches and OEM'ing them. So if you wanted made in the USA that is difficult to find.
Steve
Well one thing is for sure, when I really need a winch I want to make sure it will work. I am leaning towards the Warn set up with the 9500# winch. I may need a snatch block with it if I am really stuck. warn sells nice kits to get power to the front and rear of the vehicle also. My bumper has a winch mount built into it that can handle up to a 16,500 winch but I think the flexability of a portable unit out weighs the ultra capacity of the permanent mount.
/ Multi-mount winch advice #18
Keith when you start buying accessories shop around. Generally Warn is very proud of their stuff and you pay a premium price. It's quality equipment but can be bought for less without Warn's name on it. I carry two snatch blocks, two tree savers and four shackles. I also use a thimble on my primary Jeep and also attach using screw type shackles, no concern with coming unhooked. I also use and prefer rope over cable but it adds $200-300 to the cost of startup. When you get set up, post pics and give us an update. :)
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
2014 BMW X1 S Drive 28I SUV (A59231)
2014 BMW X1 S...
2012 International 4300 Reefer Truck (A61307)
2012 International...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
