3-Point Hitch 2305 or similar sized and the northern tool 3pt 13 ton log splitter
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #41
Hey Tunguska, I had one like that a couple of years ago.:D I still say the hydraulic one is cheaper.;)
And more dependable, it will keep working when the neighbor girls come around :D
2 quick thoughts, 1. I like the steel wings that come with the complete unit, saves toes and allows to stage logs
2. worry about safety, with a remote operator and some one else loading the splitter.....
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #43
Sorry it took so long, Pics of logsplitter in action, and the tractor dressed for winter. Fred
I see you have a foldable ROPS. Is that an option/add-on?
yes it was an add on, as far as I know the 2305 comes only with a non foldable ROPS, mine is from Femco and was a very easy switch over
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #45
Is it really worth it to get the 3pth splitter and put the extra hours on the tractor rather then a gas splitter?
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #46
The diverter would work, but the BEST solution (and cheaper also I think) is to get the Power Beyond kit to power the splitter, leaving the loader 100% functional. Might even get a little more speed out of it also because you won't have the restriction of the SCV valve and the small QD's.
If anyone's interested, I took Kenny's advice and bought the JD Power Beyond Kit for my JD790 and installed it in about 2 hours. It was very simple and the directions were clear and easy to follow. I've had more difficult times assembling my 5 year olds lego set.
I think I won a bid for a log splitter on ebay, and can't wait to see how it works.
TommyJD790..:)
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #47
TommyJD790..:)
I told you it wasn't a bad job!;)
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #48
I looked long and hard at getting a Power Beyond and a 3-point log splitter but in the end decided it would cost more and not meet my log opening, speed and force requirements, and would tie up my tractor. I just leave this splitter where I am working and cover it with a piece of roof rubber. Very convenient!
SO - i got an old BIG gas-powered splitter. I can actually take large oak rounds, maybe 24-26" dia and 20" long and lift them up to the splitter level and the splitter takes it from there. I usually bust big rounds up into 4ths so they can be easily placed on the splitter
Log Splitter Welding :: DSCN2327.jpg picture by modified_bob2007 - Photobucket
Log Splitter Welding :: DSCN2328.jpg picture by modified_bob2007 - Photobucket
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #49
I finally had my Ramsplitter 16T 3Pt logsplitter delivered this week. To me, it was a steal for $430 plus shipping off of ebay.
I had to spend some pretty good coin at the JD dealer to get the quick disconnect couplers to fit the power beyond fittings but the guy at the dealer was very helpful and figured out which parts I needed pretty quickly.
I split about 1 1/2 cord of wood in about 2 hours. My tractor is rated at 5.4 GPM, and I expected it to be slow, but it moves as fast as I can handle and it sure beats splitting with a maul.
TommyJD790
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #50
Very nice. Did that quartering wedge come with it or did you have it made?
COPPER POT & COIL (A58374)
COPPER POT & COIL...
ALUMINUM STEP LADDER (A52708)
ALUMINUM STEP...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
