My dump trailer build
/ My dump trailer build
Larry, thanks for the video! I really like that idea! Looks like I may have to buy 2 more cylinders, Greg
/ My dump trailer build #22
I recommend having a pretty substantial reinforced edge surrounding the dump box. Try as you might, occasionally it will get bumped with the excavator bucket.
Not a bad idea but if you put slots around the top of the dump box to accept 2x4's they will take a lot more abuse than metal and you can replace them very cheaply. The wood will provide a bit of a shock cushion and will help alleviate dings in the trailer and bucket.
/ My dump trailer build #23
GuglioLS,
Very nice setup, I like that gate. I never did anything fancy with my gate, it just slides in and out. Sometime I'll probably make something like what you've designed.
/ My dump trailer build #24
I also thought about using heavy metal for sides, but did not. I went with wood, and yes they get smacked and even broke, easy replace. I would rather break a board then smack heavy metal especially with my mini ex.
/ My dump trailer build #25
I used several large bolts 3/4" threaded into nuts I welded into the tailgate. I thread them through some oval shaped pipe I welded into the trailer. By lifting the tailgate slightly it opens out like a pickup and simply unscrewing the bottom it will hinge out like standard dumping gate...
Works OK but sometimes sand in the threads makes it a pain...
mark m
/ My dump trailer build #26
First I want to thank "leveller" for this thread, as I have my trailer well on the way, except for the lift geometry aspect! Also thanks, for dragging GugliosLS's thread out of the weeds! I read the whole thing! Couple questions for the "G" man: On your post #66, you comment about the hydro circuits in parallel. My limited hydro experiance is that hydro fluid would flow in the path of least resistance, if all plumbed together. Thus the rear tailgate rams would open to max, bottom out, before the lift rams would pressurize for lift? Keep in mind I'm not a ".......Electronics & Optics, Inductivly Coupled Plasma Mass Spectrometers (ICP-MS) and ICP Emission Spectrometers"......specialist! If I opt for a electro/hydro pump, that would handle this rig, what and where should I look for and where? I'm not adverse to shopping e-bay, but what am I looking for? That would certainly give me the best of both worlds having a hydro lift that would operate behind a tractor and ATV. Great build! ~Scotty
/ My dump trailer build #27
i second using 2x4s or 2x6s for the top rail we used to use them on the 10 wheel dump trucks i used to drive. when i bought my dump trailer(best investment i ever made i think) i put 2x6's on the rails and it gives you that much more room. jon
/ My dump trailer build #28
Here is a pic of one I just installed in my rig. When down, all the pressure is put on the scissors, as the hoist lifts, it is pushing straight up initially.
Could you post more pics of the scissor lift. I like the idea and would like to copy it if I could make it work.
Bill
Here is a link to a local to me hoist manufacturer. I have one of these hoist on my big dump trailer (14 footer) and it works very well. The pics on that site are not great, but may give you some ideas. I was trying to avoid building a hoist style lift for my small trailer, just to keep it simple, but in hindsite I think it may have been worth it, although I am happy with how it is working now. Here is the link Nordic I'm sure a Google search for underbody hoists would turn up better info, Greg
/ My dump trailer build #30
....snip.....snip.....Also thanks, for dragging GugliosLS's thread out of the weeds! I read the whole thing! Couple questions for the "G" man: On your post #66, you comment about the hydro circuits in parallel. My limited hydro experiance is that hydro fluid would flow in the path of least resistance, if all plumbed together. Thus the rear tailgate rams would open to max, bottom out, before the lift rams would pressurize for lift? ....snip....snip.....If I opt for a electro/hydro pump, that would handle this rig, what and where should I look for and where? I'm not adverse to shopping e-bay, but what am I looking for? ....snip....snip....~Scotty
Scotty, you got that right about the dump and tailgate cylinders being in parallel. That was by design so I didn't have to add another valve, hoses fittings etc. to my dozer, tractor and trailer to get the tailgate to work. As long as the valve is closed the tailgate holds tight, as soon as I actuate the valve the path of least resistance is the tailgate so it opens first then bottoms out then the dump cylinder starts to lift. When lowering, the bed lowers first followed by the tailgate. I have made a few more mods (improvements to the tailgate function) that I have not updated to my dump trailer build, my bad. Look forward to seeing them soon.
As far as a electro - hydro actuator or power pack unit I suggest surplus center CLICK HERE
Here are links to scissors hoists for trailers or truck beds, a little pricey if you ask me, especially if you can design a bed and cylinder on your own and get it to lift without tearing up the cylinder mounts or the trailer bed. Why bother installing a 1000 + dollar hoist? I don't get it.
scissor hoist for trailers
scissor hoist for truck beds
Larry
/ My dump trailer build #31
Leveller:
I like the way you took the extra time to finish the dump pin end of the frame.
I'm glad to see Larry posted his dump trailer video too!
In my case at least, I would not think of buying a hoist, but making my own smaller version. I don't know why I have my cylinder mounted so it pushes back, never considered turning it around till I saw your video. It looks like your way works well, and pushes up, closer to the front of the trailer. Are you happy with the way your cylinders are mounted?
/ My dump trailer build #33
Here are pics of my trailer with a high swing tailgate. You should not have any trouble with your set up,it is similar to mine & i have had mine filled with hand picked field rocks to where no more rocks would stay on,never had any trouble dumping it.
Thanks Dirtnut, I think too I will be okay with my setup. I like the idea of your high tailgate. I also like your front toolbox. More things to think about, thanks for the pics, Greg
/ My dump trailer build #37
Larry
Larry, I call this R&D, rob and duplicate their design.
Bill
wushaw, thanks for the link to your build. I just read the whole thing. Good job! I made some more progress on my trailer today, got the axle mounted, hitch is on, and started doing the final welding. I did take pics, but I will have to wait for the weekend when my son comes home to post more pics. He showed me how, but nothing to do with computers works when I try, Greg
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
