2015 HST creeps??
/ 2015 HST creeps?? #1
bhostasa
Central OH
Mahindra 2015 HST
Hi everyone. I have a 2015 and for the last 6-7 months when I get off of the tractor to do something the tractor continues to slowly travel in forward or reverse (whichever direction I was going before I jumped off). I set the parking brake before I jump off of it but it still moves.
At first I thought there was a grease fitting that needed filled on the HST pedal but if it's there I haven't found it. Does anyone know if there is an adjustment that can be made or if there actually is a fitting that I'm just missing?
/ 2015 HST creeps?? #2
First of all before you get this fixed I'd make sure you put the tractor HST in neutral when you get off, last thing you need is to be run over by it as this could become a safety issue. Have you contacted your dealer?
This is only a guess from what I'm reading in my service manual for my tractor but to me it could be either the pressure in the HST may be the issue. Have you checked for the correct oil level in the HST. Or the adjustment for the Stopper HST pedals are our of adjustment.
At what engine RPM does this happen...Idle or 2500?
What about the Speed Control Level does it appear to be operating correctly?
Also in my manual I show three grease spots for the HST linkage, but I can't tell how these are greased.
/ 2015 HST creeps?? #3
My 2615 creeps as well, I just make sure to tap the pedal until it is in neutral before I get off. I think the rocker pedal is too tight, but I haven't taken the time to look at it yet.
/ 2015 HST creeps?? #5
Something else to try if you don't have any grease fittings then get yourself a can of PB Blaster spray oil and hit all the linkage spots, might help.
/ 2015 HST creeps?? #6
bhostasa
My 2015 creeps the same way. (It's about 6 years old). I haven't looked into it either. I just make sure I put in neutral and put on emergency brake lock for now.
I also feel a wierd kind of vibration under my foot on the "forward"/ "reverse" pedal when taking off from a start. I'm hopeing it's just adjustment in the linkage or something...
Patiofarmer
/ 2015 HST creeps?? #7
You have some sort of adjustment problem,:( but there is no way that the tractor should move at all,:eek: not even a teeny tiny bit with the emergency brake on. You are not applying the brake hard enough if the tractor moves, AT ALL. If you are indeed applying the brake properly, then there are other problems that should be taken care of.
Good luck
/ 2015 HST creeps?? #8
Good luck
Agreed. I have a Bobcat, but I'm sure generally they're the same. My manual instructions for adjusting the parking brake say it should hold the tractor in neutral on a 15 degree slope. Unless I'm at PTO RPMs, I'll stall the tractor if I try to drive with the brake on, too. Even at PTO RPM, It bogs pretty hard and barely moves.
-rus-
/ 2015 HST creeps?? #9
Did you check and see if the cruise control lever is engaged? I had my tractor doing that once and at first I thought the brakes were broken or something in the pedal was stuck or bent. After living with it for a while, one day I had a "duh" moment when I realized the cruise control lever was engaged.
/ 2015 HST creeps??
Sorry about the delay in response guys. I was back on the tractor this morning for the first time this week.
I sprayed some PB Blaster in the area, checked the fluid (it was fine) and still had some creeping throughout the morning. I went back through my owner's manual also. There is a section on adjusting the brake and clutch pedals but nothing on the rocker pedal. There are also no grease fittings for the pedal.
I really think the issue is that the pedal isn't coming clear back into the proper position...like maybe it's too tight or something. I just haven't found any possible adjustment to make yet.
/ 2015 HST creeps?? #11
Is it possible you have a rubber floor mat that has shifted binding the pedal on it's return?
/ 2015 HST creeps?? #12
If you look at the underside by the pedal, you will find a pullback spring that works for forward and reverse. It can be adjusted pretty easily. Had to do it to my 1816.
/ 2015 HST creeps?? #13
If the 2015 is like the 2615, under the floor board there is a valve with a rod on both ends. The ends are threaded, and there is a locking nut on each end. I think your valve is probably a tad off center. Try loosening both nuts, and see if that allows the valve to return to a neutral positon. If it does, re-tighten, and check to see if all is well. This is only and educated guess. :)
/ 2015 HST creeps?? #14
After read Wanderer53 posting which seemed to be good ideal I started looking more into my manual and found the following which for whatever reason I overlooked so I've scanned and have attached the information below, hopeful this will help.
Added another picture which should help identify the components.
/ 2015 HST creeps?? #15
Exactly what he needed. I tried to scan that for him a few days ago but for one reason or another, neither the shop or home computer would scan it and transfer it from the scanner. Even though I know the problem is probably me, I hate computers sometimes.
2004 International 4400 Single Axle Dump (A62613)
2004 International...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
2023 JCB S3246E...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
