Grading scraper blade ?
/ scraper blade ? #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I have a chance to get a Rhino heavy Duty 6' scraper blade it is rated for a 50 HP tractor can I put it on a Kubota B7800 30 HP
/ scraper blade ? #2
I don't pretend to be any kind of an expert, but unless the blade assembly is too heavy for your 3 pt, which seems very unlikely, or it's not a category 1 implement, I can't see how it could be a problem..
Let's see what I just walked into LOL..
/ scraper blade ? #4
Oh, one thing you definitely need to check, that I forgot to mention. IF the implement is a category 1, then you need to measure the height of the pins when it's on the ground. Then measure the height of the connection points on your tractor (don't know what they're called- the holes where the pins go) when they are in the top position (you might be able to adjust them.) Be sure that height is high enough so that when you raise your blade, you can do whatever else you want to do with the tractor when it's on there..
The reason I bring this up, is I recently bought a 6' Woods blade for my NH TC 26 DA and even with the highest adjustment of the 3 pt hitch, when the blade is adjusted at the angle I want it, it's only off the ground by a few inches. This limits what I can do as far as driving the tractor on uneven ground when the blade is on the tractor. I went for the Woods blade because it has the option of snow shoes, which I wanted, and a lot of other brands do not. I would add too that for snow removal, a 7 foot blade would be much preferable to a 6 foot, because it allows more of a distance between the tires and the snow bank. I knew this going in, of course, but the 6 foot blade was on the lot for substantially less than I would have to pay for an ordered one.
/ scraper blade ? #5
Duh.. obiously the snow removal stuff doesn't apply if you're talking about a box scraper.. but the height concern still might..
/ scraper blade ? #7
Unfortunately the height problem seems to be common place with rear blades. :( I'm starting to think that the OEMs think that these are only used on a smooth and level surface. :eek: Either that or they think that everybody has a hydraulic top link so that you can raise the blade
/ scraper blade ?
our tractor should arrive next week I'm thinking I should load it up take it to the Dealer that has the blade put it on and make sure it will work before shelling out $650.00 ??
/ scraper blade ? #9
Won't hurt, but what you will most likely find is that all the blades will fit the same. So if it works, great, if not and if you want a rear blade, you may have to either get a hydraulic top link or modify the hitch in some way. Keep in mind that there are different height adjustments on the 3PT hitch and you might need to make some adjustments to that to accommodate the rear blade.
Good luck
/ scraper blade ? #10
My little Jinma will lift my 7' Woods RB-7 blade a good 30" off the ground. My Ford 861 will lift it about 24". I think its a tractor issue.
Chris
/ scraper blade ? #11
I would make sure before buying. Those heavy duty blades, even if compatable Cat 1, are really heavy--if they are truly "heavy duty." Your machine (knowing its size--my neighbor has one) will pull that blade if the conditions are just right, but I would have some reservations about its ability to use that blade to its fullest. Also, not all Cat 1 hitches (for example) are the same. This only related mainly to the spacing and lift height. Just because something is Cat 1 compatable does not mean it works well. My little tractor has a Cat 1 hitch as did my seven other tractors that were larger. They had thicker arms and chains, etc. My impression, without seeing the blade is that a medium duty 250-350 pound blade would suit your machine better, and if this blade is truly heavy duty it might weigh 800+ pounds which would be a real struggle for a tractor of your size to pull, except in ideal conditions.
John M
/ scraper blade ? #12
Chris
Chris, when you are hooked up to your Woods rear blade, what height do you think that the 3pt ends are at? Any chance of any pictures?
/ scraper blade ?
/www.servis-rhino.com/products/landscape-construction/blades/utility-rear-blades/
the heaviest they show is under 500 lbs (The Dealer near me has a LR-500 6' cat 1 382 LBS $ 650.00)
(update) another Dealer near by is offering a( New Rhino LR-350 7' cat 1 395 LBS for $499.00 ) 7' seems like a wide blade for a Kubota B7800
/ scraper blade ? #14
I would think that a 6' wide scraper blade is too narrow for a 50HP tractor.
We have a pretty heavy duty 7' Tufline rear blade on a Kubota L4310. Heavier is better with rear blades - my dealer told me of having to replace lighter duty blades due to crimping.
As other have posted, check your lift capacity and/or ask you dealer for a trial fit.
/ scraper blade ? #15
The heavier a scrape blade is suppose to be seems the taller the blade is which makes sense as the larger the load the heavier built the blade must be. It has been my experience those who rate the HP for those blades do with much greater belief in the blade than they should. Had a blade (no idea the brand now) rated for about a 45 to 50 hp and destroyed with a 27 hp Kubota. Have one now rated for about 80 HP King Kutter and have had to rebuild it almost totally on a 68 hp Kubota. As to lifting the blade, some Kubota's have two different attachment points on the lift arms to give either greatest lift capacity in weight or in height. Also you can normally have a lug to mount lift pins on a lower position for greater lift. If you use it to cut hard dirt, weight is a great friend.
/ scraper blade ? #16
[QUOTE (update) another Dealer near by is offering a( New Rhino LR-350 7' cat 1 395 LBS for $499.00 ) 7' seems like a wide blade for a Kubota B7800[/QUOTE]
I think the 7 foot could work depending on what you're doing. If yo're moving heavy stuff gravel/lots of dirt maybe to big. If you're moving snow it would be fine. The other question is do you have a grader box in case the material is too much for your scraper blade.
The other question is any chance you might trade up to a bigger tractor? I just sold a 6 foot and am looking for a 7 foot. I'm looking for something heavier for mine.
/ scraper blade ? #17
Not sure. I have never moved them in 700+ hours. It works fine with my BH, Bush Hog, Finish mower, Blade, and Post Hole Digger.
Here is the only pic I can find with the blade on it. I will take one tomorrow.
Chris
/ scraper blade ? #18
I just went out and looked it over. Too dark to get a picture. The lower 3 point arms have 4 holes drilled in them to accept the lift arms. It has the lift arms pinned into hole #2 if counting from the tractor out to the implement. I never paid any attention where it was because I have never adjusted it. I guess the closer to the implement its pined the more it will lift but yield less lift height.
Chris
/ scraper blade ?
/ scraper blade ?
for something heavier for mine.[/QUOTE]
thanks for your reply Medicshawn My first tractor ever will be delivered next week. Kubota B7800 w/fel. Just looking to move snow right now hoping to spend my scraper blade $ with a wise educated decision. James River has the new Rhino 7' ask for Greg.
7002SFL (A61572)
7002SFL (A61572)
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
1999 Trailmaster Aluminum 407 T/A Chemical Tanker Trailer (A64194)
1999 Trailmaster...
KMC 18' FIELD CULTIVATOR (A64278)
KMC 18' FIELD...
