Battery hooked up backwards,OOP!
/ Battery hooked up backwards,OOP!
After the alternator, voltage regulator and ignition was replaced I finally found the fusible link in the wad of wires near the starter. I removed it and tried a 10 guage wire and presto their was power and lights! The local parts place did not have the same fusible link, so I made do with what they had and now me a little JD are back in business. Thanks to all that reponded!
/ Battery hooked up backwards,OOP! #42
Make sure you order and replace the fusable link and don't forget.
/ Battery hooked up backwards,OOP! #43
I'm not an EE... but growing up around the family car business... more than a couple of times I've tied fried fusible links to reversed batteries...
Don't know the how or why... one time I even saw the smoke coming out under the hood of a late model Cadillac where the battery had just been put in the wrong way... and that's why I mentioned it back in post #6
/ Battery hooked up backwards,OOP! #44
Great news sola mesa. Glad you are back in business and the JD is healthy again.:)
/ Battery hooked up backwards,OOP! #45
Let me just say, you are no idiot. I am an EE. I have hooked the battery up backwards on my boat before. It is called "having too much on your mind".
Joseph
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
