4310 temp gauge
/ 4310 temp gauge #1
toweeman
marietta, ga.
jd 4310 2005
I own a 05 4310 with a temp. gauge problem. After about five minuites the temp. gauge goes to full hot. I have measured the temp. with an infra red gauge and it is normal. I changed the sending unit but the problem still exists. Any suggestions?
/ 4310 temp gauge #2
Usually when the gauge goes to the max reading it is a ground issue. Try tracing the wire back to the gauge to see if the wire is exposed and grounding out.
/ 4310 temp gauge
The gauge goes back to cold as soon as the temp. sender is unpluged. This tells me that the wiring is ok. Im thinking it is a gauge problem.
/ 4310 temp gauge #4
Your thinking is bass ackwards. If the above is the case, the sender is bad. The guage is reading what the sender tells it. If you take a ohm reading the sender likely has a short when warm.
/ 4310 temp gauge #5
I agree with this too.
/ 4310 temp gauge
after spending 75.00 on a new j.d. sending unit last month the problem still exists. I'm a thirty one year bmw, mercedes mechanic and the sending unit was my first choice.
/ 4310 temp gauge #7
The new sending unit may be bad too. Just because it is new doesn't mean much.
/ 4310 temp gauge #8
It is very rare the sending units go bad, let alone two in a row. I am still thinking that a wire is grounding out somewhere.
/ 4310 temp gauge
with the temp sending unit unpluged the temp gauge goes to cold. my thought is a second bad sending unit or temp gauge. sadly the only way to get a new gauge is with the entire 500.00 instrument cluster. before i do that i will ohm out the sending unit from cold to hot. if it is the gauge ill just add a aftermarket gauge.
/ 4310 temp gauge #10
I would agree with this, I would be reluctant to reward Deere for their poor design. Gone are the days when reasonable repairs and their costs can be made.
/ 4310 temp gauge #11
I looked at the wiring diagram and the power goes from fuse f 5 to the guage and then to the sender. The sender a variable ground dependant on temperature. Check to make sure that the ground from the motor to the frame is good. I still think the problem is in the sender or a ground problem from the engine to frame or frame to battery. It is very strange it only does it after the tractor has warmed up.
Unplug the sender and hook a wire from the white wire and touch it to ground and watch the guage. It should go full hot to full cold with grounding and ungrounding. If it does, the the problem is not the guage.
Keep us posted I am curious.
Frontier Forks (A64126)
Frontier Forks...
6 Row Corn Plow (A64127)
6 Row Corn Plow...
Exmark C2-96 (A64127)
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
