Chains Which chains?
/ Which chains? #1
jaybrad
Gold Member
Central Maine
Massey Ferguson GC 2310TLB
After coming very close to being very stuck last year (and almost doing so tonight), I am again considering chains, but more seriously than in the past. My tractor is a GC2310 with a rear snow blower and FEL.
I found a couple of web sites mentioned by others on TBN, but that then raises the question of which style? 2 link? 4 link? v-link? other>
We have a paved driveway, which is no problem. The problem comes when I try to clear a path so that we can get heating oil delivered. To do that there are a couple of points where I have to negotiate a couple of corners where the land slopes enough that the front wheels start to spin and head downhill. Once that happens, it become iffy as to whether I will be able to get out, or not.
So what I am seeking is a chain that I can leave on all winter that won't tear up the driveway, but that will give me the added traction I need to maneuver a couple of corners on a slight slope.
Any suggestions?
Thanks,
Jay
/ Which chains? #2
The two link may serve your purpose.:D
Four links may ride rough.
v- bars may leave marks on the pavement.
/ Which chains? #3
Any suggestions?
Thanks,
Jay
Get some garden tractor rear tire chains and put them on the front wheels. The problem will go away at very little cost. I got some at our local farm supply store for around $15 on a clearance table.:D:D:D
/ Which chains? #4
JAY,
HAMMOND TRACTOR keeps them in stock,and they aint real costly.Ive got them on my rear ags and i have a real steep drive-no problems
ALAN
/ Which chains? #5
The V-bars will scratch up your pavement and they wear down quickly if you spin them allot so I wouldn't go V-bar.
DEWFPO
/ Which chains? #6
I'd suggest 2 link for smoother ride.
Not V or studded as they will mark pave.( dewfpo is correct)
Rear rather than fronts as front diff is weaker differential and U don't want to work it hard.
If steering is difficult, use your differential braking to help the turns.
I use 2 link on turfs and they work great! (rarely need front assist)
/ Which chains?
Do you use the heating oil in your tractor too ?
No. I did in my JD755 many years ago, but at that time I had an in ground tank and needed more fuel.
Now my tank is in the basement and I don't use nearly enough of it to go through the hassle.
But it's what keeps our house warm, so I have to keep the fill pipes clear so the nice man can deliver it to us. Which inevitably will happen a few days after we get a lot of snow. :rolleyes:
/ Which chains?
I went to the dealer and bought a set of 2 link chains for the rear tires only.
The guys at the shop said that they really did not recommend using chains on the front of a small 4wd like mine because it can cause significant damage to the front differential, and the clearance is pretty close.
So I decided to take their advice and give this setup a try.
Jay
/ Which chains?
FWIW, just wanted to add that I installed the chains today and what a difference it made!
No problems in some of those traditional trouble spots around the house.
The biggest problem will be that since I can more easily get around, when I do get stuck (probably just a matter of time), I am more likely to be *very*stuck.
Fortunately for me, I have several neighbors with tractors (most larger than mine).
Unfortunately (for them), they are all orange....:rolleyes::D
/ Which chains? #12
Jay Brad, Glad to hear that the chains did the job. The last storm I had down here, I found myself spinnig more than I liked. So I fitted up some V bar 4 link chains for the rear in hopes that it will solve that issue. So with you response I should be in good shape. Thanks for the great input.
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
