Chains Which chains?
/ Which chains? #1
jaybrad
Gold Member
Central Maine
Massey Ferguson GC 2310TLB
After coming very close to being very stuck last year (and almost doing so tonight), I am again considering chains, but more seriously than in the past. My tractor is a GC2310 with a rear snow blower and FEL.
I found a couple of web sites mentioned by others on TBN, but that then raises the question of which style? 2 link? 4 link? v-link? other>
We have a paved driveway, which is no problem. The problem comes when I try to clear a path so that we can get heating oil delivered. To do that there are a couple of points where I have to negotiate a couple of corners where the land slopes enough that the front wheels start to spin and head downhill. Once that happens, it become iffy as to whether I will be able to get out, or not.
So what I am seeking is a chain that I can leave on all winter that won't tear up the driveway, but that will give me the added traction I need to maneuver a couple of corners on a slight slope.
Any suggestions?
Thanks,
Jay
/ Which chains? #2
The two link may serve your purpose.:D
Four links may ride rough.
v- bars may leave marks on the pavement.
/ Which chains? #3
Any suggestions?
Thanks,
Jay
Get some garden tractor rear tire chains and put them on the front wheels. The problem will go away at very little cost. I got some at our local farm supply store for around $15 on a clearance table.:D:D:D
/ Which chains? #4
JAY,
HAMMOND TRACTOR keeps them in stock,and they aint real costly.Ive got them on my rear ags and i have a real steep drive-no problems
ALAN
/ Which chains? #5
The V-bars will scratch up your pavement and they wear down quickly if you spin them allot so I wouldn't go V-bar.
DEWFPO
/ Which chains? #6
I'd suggest 2 link for smoother ride.
Not V or studded as they will mark pave.( dewfpo is correct)
Rear rather than fronts as front diff is weaker differential and U don't want to work it hard.
If steering is difficult, use your differential braking to help the turns.
I use 2 link on turfs and they work great! (rarely need front assist)
/ Which chains?
Do you use the heating oil in your tractor too ?
No. I did in my JD755 many years ago, but at that time I had an in ground tank and needed more fuel.
Now my tank is in the basement and I don't use nearly enough of it to go through the hassle.
But it's what keeps our house warm, so I have to keep the fill pipes clear so the nice man can deliver it to us. Which inevitably will happen a few days after we get a lot of snow. :rolleyes:
/ Which chains?
I went to the dealer and bought a set of 2 link chains for the rear tires only.
The guys at the shop said that they really did not recommend using chains on the front of a small 4wd like mine because it can cause significant damage to the front differential, and the clearance is pretty close.
So I decided to take their advice and give this setup a try.
Jay
/ Which chains?
FWIW, just wanted to add that I installed the chains today and what a difference it made!
No problems in some of those traditional trouble spots around the house.
The biggest problem will be that since I can more easily get around, when I do get stuck (probably just a matter of time), I am more likely to be *very*stuck.
Fortunately for me, I have several neighbors with tractors (most larger than mine).
Unfortunately (for them), they are all orange....:rolleyes::D
/ Which chains? #12
Jay Brad, Glad to hear that the chains did the job. The last storm I had down here, I found myself spinnig more than I liked. So I fitted up some V bar 4 link chains for the rear in hopes that it will solve that issue. So with you response I should be in good shape. Thanks for the great input.
Landhonor Mini Excavator Ripper Tooth (A66285)
Landhonor Mini...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
