It' Finally Coming Down!! If This Keeps Up..
/ It' Finally Coming Down!! If This Keeps Up.. #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
Finally, after a much delayed winter, it is finally coming down.
If this keeps us, it can only mean one thing!!!!
/ It' Finally Coming Down!! If This Keeps Up.. #2
That should even the odds. :)
/ It' Finally Coming Down!! If This Keeps Up.. #3
Nice setup!
I'm doing my final road work today. Then the grader is going to get put away and the blower greased. Bring on winter. I want to go fishing!
/ It' Finally Coming Down!! If This Keeps Up.. #4
What do you use on the back for weight ?
I use a 48'' KK tiller on my BX1500 when plowing snow.
Well guys, I just plowed for the first time. Piece of cake!!
Granted, it was only 4", hardly a blizzard, but shoot, I didn't even use 4 wd.
And, btw, the front pvc worked like a charm!! Highly recommend it. I think the trick might be getting the split cut just right. Too little slit and you can't mount it, but too big and there isn't enough tension to keep it on. I used a table saw, after the first cut, I rotated a blade thickness and ran it through again. Perfect. Very hard to get on, which is what you want.
LB- used nothing other than my wheel weights, which I am beginning to believe it.
/ It' Finally Coming Down!! If This Keeps Up.. #7
Both the tractor and plow are way too clean and shiny.;) ...nice setup.
/ It' Finally Coming Down!! If This Keeps Up.. #8
Only got a little over 2" here. At least you had enough to do a 'debug' run and try things out. Glad the PVC is working for you.
Dave.
Stay tuned everyone!!
There is a possible MONSTER brewing in Colorado/Oklahoma right now.
Yes, tonight was just a little shake down cruise. Gosh it was fun!
12-14 inches already on the ground. Stunningly beautiful.
Might get another 6" more tonight, we shall see.
/ It' Finally Coming Down!! If This Keeps Up.. #13
I'm as ready as I can be - forecast is for 20-25 cm of snow followed by rain, all accompanied by 100 kph winds
  1. Filled up with diesel
  2. Bought license plates so I can go on the road to get the neighbours dug out
  3. Installed ABS edge on bucket
  4. Bought long johns
  5. Bought insulated coveralls
Now I just have to remember where I put that toque!:D
/ It' Finally Coming Down!! If This Keeps Up.. #14
Seems like the storm pickup some speed while passing though..8" fallen and just about stop..winds are picking up tho. :(
Hope the storm somewhat bypasses you. NS.
/ It' Finally Coming Down!! If This Keeps Up.. #15
About the same over here Thomas, probably around 6"-7" and tapering off to the fine stuff. Hope we don't get sleet or rain. If we do, I'll wait until tomorrow am to clear the drive. It was 10* this morning and now it's 23*.
Dave.
/ It' Finally Coming Down!! If This Keeps Up.. #16
We got a lot of rain on our snow. One big sloppy mess right now.
/ It' Finally Coming Down!! If This Keeps Up.. #17
Hey it snowed on the Texas Gulf coast last week. So, is it suppossed to snow in south Texas before Michigan?:eek:
/ It' Finally Coming Down!! If This Keeps Up.. #18
In my area, Montreal, it was/is nice snow blowing snow, not wet sticky stuff like the first storms often are.
Also the ground is frozen so my gravel is still in the drive.
About 10 ins so far, and that is blown clear off of my property thanks to my Mitsubishi and Bervac blower.
Heated cabs are sure great as is having both front and rear wipers.
Will do final cleanup tomorrow.
/ It' Finally Coming Down!! If This Keeps Up.. #19
We ended up with about 10" and no sleet or rain. Still 24* and dead calm now. Just finished cleaning the driveway. Gave it all a good clearing as it is supposed to get very windy and cold later Thursday thru Saturday. One storm down and a few to go :)
Dave.
/ It' Finally Coming Down!! If This Keeps Up.. #20
We had 15" yesterday and another 15" today which I will have to take care of tomorrow. Most of it was lake effect snow, only a portion was due to the storm that passed by.
I have never seen my mechanical barometer with such low pressure. It was pegged at the minimum - 29"
Case IH Farmall 70A Tractor (A64047)
Case IH Farmall...
2014 International DuraStar 4300 S/A Dump Truck (A61573)
2014 International...
International Tractor (A64047)
International...
2021 LIUGONG 925E EXCAVATOR(INOPERABLE) (A63569)
2021 LIUGONG 925E...
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
