plow mount
/ plow mount #1
NBstunter
new brunswick canada
2006 kubota L2800
so i have a kubota L2800 and i have a winch with it and pull wood out with it most of the winter and im sick of changing the winch for the snow blower every storm so i wanna put a plow on the front it needs to be able to be put on an angle and im wondering should it go on the end of the bucket arms or on the ftont of the tractor? now my winch the cable comes out very high on it and pulling wood even with the bucket on it enjoys to wheelie so i NEED something heavy on the front so im not wheelieing out of the woods. i don't have a plow yet im looking at a few the number 1 thing im trying not to have to do is put more hydraulic valves on it i wanna run everything off the 1 valve for the bucket ill need different rams witch i have i just cant afford another valve
thanks Stephen
/ plow mount #2
I also have L2800,didn't want to keep swaping bucket to snowplow each storm..pull one pin frees plow,manuel angel tho.
/ plow mount #3
Ok, ill bite, whats the round black metal tab top center in the bucket?
/ plow mount #4
For trailer ball.
/ plow mount #5
Thomas that's a nice quick setup!- Do you leave the mounting plate bolted to the bucket all the time ?
I also like how you have the hitch.:)
Thanks!
/ plow mount #6
Low Bucket
"Do you leave the mounting plate bolted to the bucket all the time ?"
Yes,I do leave mounting plate attach only during winter months.
1/4" plate..pitch towards back of bucket,on back side 3/8"x 4" flat stock for strenght.
Thanks for the words. :)
/ plow mount #8
We do meet our share of smart people on this site, what a great idea Thomas, thanks, I'll use it asap
Dan
/ plow mount #9
Dan W.
"We do meet our share of smart people on this site"
Sure have and may it contiune. :)
/ plow mount #10
That's a cool set up! I am trying to figure out how you would angle the blade if needed? Is that what the hole is for? To slip over the centering post one way or another?
/ plow mount #11
Hapis.
"you would angle the blade if needed? Is that what the hole is for? To slip over the centering post one way or another? "
Hole does nothing.
Center posts helps keeping frame in line..less stress.
Plow rotates 45 to 45 degrees w/settings in between,drop 1"pin which catch plow and frame.
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2021 Scout 210 Dorado 21ft Boat w 18ft S/A Boat Trailer (A61574)
2021 Scout 210...
Hydraulic rail grinder (A61307)
Hydraulic rail...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
