Firewood Gathering With A Power Trac
   / Firewood Gathering With A Power Trac #41
It sounds to me as if you are getting too much rain in the central channel.
You could try a piece of perforated sewer pipe, at least 8" in diameter, and make sure it extends above the stack, with a rain cap.
You could also try a small metal kid's snow saucer inverted over the top center, and build it the way you are building it now, but make sure the edges are at least 3-4" above the pile (three split logs and a cinderblock on top would do.
All the best,
Peter
Hello Everyone !
I have built 2 holtz Hausens already with some interesting results. Both were built on 8" cinder blocks to keep them off the ground. 8' diameters each, approx 5' high. #1 built Nov '08, broke down May '09, The "ring" wood very dry, vertically stacked wood "damp":( #2 built Apr'09, broke down Jul'09, same result. I was thinking.... has anyone built one w/o the center wood???? I think this would speed up air flow, or maybe just stack some pallet wood in the center to prevent it from possible collapse????. I agree that the amt. of wood in a circular H.H. is great, just that all the center wood doesn't really get dry. I'm from NW WI . Any others out there with similar results or suggestions?????
   / Firewood Gathering With A Power Trac #42
Thanks Ponytug.......yes I agree with you about the water in the center of the inverted cone roof.... One other question... maybe it's the hour of the night or the huge dinner I had ....but I have a brain fart about the split logs and cinder block?????? over the central channel then the circular kids sled upside down???????:confused::eek:.
   / Firewood Gathering With A Power Trac #43
Sorry to be unclear.
1) bottom layer of cinder blocks, for ventilation. (If possible, leave a hole at the center of the holzhausen.)
2) center pipe.
3) build holzhausen up with wood, centering the pipe.
4) finish holzhausen.
5) put an inverted kids saucer over central portion of the holzhausen, with ~3 logs to space it up off the wood, and not capping the pipe. This will shed rain.
6) place a cinder block on top of saucer to keep it from blowing away.
I hope this helps.
Peter
   / Firewood Gathering With A Power Trac #44
2) center pipe.
I hope this helps.
Peter
Ah..... I see said the blind man with a hammer and saw!!!! Thanks... makes good sense !!! Will give it a try.... going to build another Holtz Hausen this week, and will use your suggestions.... I will let you know how it goes:)
Well, I brought home my last trailer load of logs today that I cut this spring and split about 2/3 of them. The stack is a tad over 7' now. That's as high as I can reach. I resorted to tossing about 20 pieces at a time up onto the top then using a ladder to get up there and arrange them nicely. I have enough logs to split to get it up to about 9', then I am going to top it with thin pieces that have bark on them and some scrap plywood that I got from work.
A few notes bullet marked by emoticons....
;) I'm trying to keep it tapered slightly in to keep it from falling over.
:eek: While it only takes up a 10 foot circle, I'll have to admit that once you get over your vertical reach, it then becomes more work than stacking conventionally.
:) I'm fortunate that I can build the stack in a place where I can back my trailer in and move the logs from trailer to splitter to stack.
:eek: Wood is heavy! I have some cherry logs that I cut into 64" lengths so I can get four 16" pieces out of them. I used the forks to load two of them onto my car hauler trailer and squeezed the tires of the PT425 between them. They are over 18" in diameter as I have to cut them from both sides with my 18" saw. A few of them are tipping the PT425 on its nose if I turn, so I'm guessing in the neighborhood of 500 to 600 pounds. I'm getting about 20 to 24 pieces of firewood out of each 16" piece, or about 80 to 90 pieces from each log.:eek: Some of the 16" pieces before splitting are so heavy that I cannot pick them up. I have resorted to rolling them off the trailer after cutting and building a ramp of split pieces so I can roll them up onto the splitter.
:cool: Handling firewood for 5-6 hours every Saturday and Sunday is a good workout.
:p I cannot move anything but my fingers. :):D
   / Firewood Gathering With A Power Trac #46
My Holz Hausen! :)
First pic is the ring 10' in diameter.
Second pic is paint mark at 8'.
Third pic is first course of split wood at an angle inward.
Fourth pic is several courses of split wood angled inward and internal area of circle with wood both split and small unsplit pieces stacked vertically.
After it was about 3' high I put another course of shims around the outside ring to keep the wood angled in and continued. I am up to about 5' high now. I split a 10' diameter by 5' high in about 10 hours. That's about 3 cords, according to the Holz Hausen instructions. :)
Your getting pretty creative with that wood. I'm having three trees taken down this Sat. I may follow your lead and stack mine into a wood sculpture ...:)
I have 2 propane fireplaces one upstairs and one downstairs. The upstairs is a real wood fireplace with an insert. Wish I could talk the wife into letting me take the insert out and burn real wood.. She likes her creature comforts. I'll sure have enough of it...
   / Firewood Gathering With A Power Trac #47
Yeah I know it's not a Power Trac (Humor Me) ...We felled a few trees yesterday, will make for some nice firewood for my friends and neighbors. Two trees out front and one more around the back I'm still working so far, I've been stung 3 different times :cool: When the trees came down it sturred up an under ground yellow jackets nest ouch!...:rolleyes:
   / Firewood Gathering With A Power Trac #48
Hey moss, did you ever finish the HH? I started on one today, nothing too elaborate 10 diameter and not sure how high yet! lol. I'm currently at about 5 ft.
Do you believe it has decreased your drying time any?
   / Firewood Gathering With A Power Trac #49
A little late, but -
Dang, Barry - is that you? Yer a big dude! That chain saw looks like a toy in your hand!
I'm glad that you realize that even a small tractor beats a big dude! I know too many big guys who are crippled because they tried to out-muscle a machine.
When are you going to step away from the Orange Side and get another PT?
Edit - BTW, please step a little farther out from under that bucket - yer makin' me nervous!
Yes. I did. I just forgot to post the finished pictures. Here goes! :)
First picture is a wider shot.
Second is me in front of it facing south. I'm 6' so the outer edge is about 7.5' high. The center of the pile is right around 8'.
Third picture shows the slabs I used on top to shed rain.
Fourth shows that I don't trust the slabs so I put some plywood scraps on top with ropes around the center post. As I remove wood the ropes slide down the pole and the plywood scraps come down with it.
I've been burning since October 1st; all but 4 days. I had about a third of a cord already in the basement and used that the first 3 weeks of October. I broke into the Holz Hausen about the last week of October. I have about a month's worth of wood in the house and the HH is down to about 6' on the outside edge. So, I think I have enough to last through the end of February for sure.
As for drying faster.... no way it is drying faster than conventionally stacked wood. There is just no way it can because the ends are hidden from open air circulation as compared to wood stacked in single wide rows. However, it sure takes up a LOT less space in my yard. I plan on making two smaller ones for next year.
Getting the wood off the top of the pile is not a problem. I use a long handle garden claw with 4-5 fingers on it to pull them down. Now that the pile is 6' I can just take them off by hand.
   / Firewood Gathering With A Power Trac #51
Hi there Gravy , nice to see someone is still mature enough to talk to me on here. Of course in their defense I do realize the title was collecting firewood with a power trac. Still I would have said hello if positions were reversed.
The older I get the more this little tractor earns its place around here. As for the Orange, once I replaced a few parts on it and changed out all of the fluids, it runs so **** well not sure it's ever going to wear out. I've made quite a few attachments for the front bucket and many more in the works this summer. I have a grader blade for the back along with a post hole digger that work well. The previous owner just ran it to death and didn't maintain it at all from what I can see.
It does everything I ask it to do just like the little 180 did. Love the diesel plenty of power. My only complaint would be the smaller front wheels when I hit a large rut with a heavy load in the bucket. Have to shift into 4x4 to pull me up and out. I'll be moving up to the larger wheels of the BX 25 though soon, that should make a big difference.
Looks like I may have missed my window for another PT at least until this one gives up the ghost. If and when it does, then I will be in the market for another Power Trac. A 422 most likely I do love the PT can't be beat for the money or the versatility. Thanks for saying hello and I'll try to stay out from under those buckets. Take care :)
   / Firewood Gathering With A Power Trac #52
MossRoad,
David,
Why is News/feedback closed with a lock on it? Why can I not post in this area? What is permalink.
   / Firewood Gathering With A Power Trac #53
MossRoad,
David,
I just posted a test reply in the News/Feedback forum and it works fine for me. :confused:
   / Firewood Gathering With A Power Trac #54
Here is the one I made, it's nothing fancy. It is 10ft diameter at the base and about 7-8ft tall. This method of stacking is definately more work, and I'm also doubtfull it will speed the drying time, but it is a good way to put alot of wood in a small area!
I know my wood is not split in very small peices, it's because I'm using an outdoor wood boiler this year and it has a big fire box.
MossRoad,
David,
Are you sure the lock is on the News/feedback forum or is the lock just on one of the threads inside it? PM me if you are still having difficulties. ;)
Yes, those are BIG chunks! :D I wouldn't be able to get them in my stove! :p
WHAT ARE YOU TALKING ABOUT??? :p
You know you are always welcome in any TBN forum, and especially in this one! :D
It was almost 1:00am and I was pooped! :rolleyes:
I wanted to ask you about that chainsaw in the picture. I have a smaller one with the same tool-less tensioner. I cannot keep it tight. You have any tricks or tips?
   / Firewood Gathering With A Power Trac #58
Mine is the 20 -inch Poulan Pro PP4620AVHD. Great chain saw for the money.
The trick is order the old style chain tensioner for it and, trash the new one... works like a charm. The old style tensioner has a screw adjustment with a locking nut. It will fit the following models. If yours is a poulan and on the list below it should also work for your model. The part number is
Poulan 530054819 Chain Brake at Partstore.com
Part Number: 530054819 | SKU: 8913268
You may be able to find it cheaper somewhere else online, they get you on the shipping. Now go back to bed and get some sleep. :rolleyes:
Poulan Poulan Pro 295
PoulanPRO Poulan Pro 295
Poulan PP4620AVHD
PoulanPRO PP4620AVHD
   / Firewood Gathering With A Power Trac #59
Barryh,
Hi Barry, good to see you are using that little orange tractor. I have a Kubota B-9200
hydrostatic 4WD. I use it mostly to grade my road. Had it before my 1445 acquisition. I also have a Ford 8N that needs to go. Stay in touch my friend.
Poulan PP4620AVHD
Mine's the PP4218AVX. I called Poulan today. They have a kit to convert it back to a tool required chain tensioner, which is fine by me. :) I need my serial number, so I will get it ordered tomorrow.
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2022 John Deere 5055E (A60462)
2022 John Deere...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
