Headlight bulb type(s) ??
/ Headlight bulb type(s) ?? #1
Spudgunner
Gold Member
Central Idaho Mtns
Kubota BX-23 & Toolcat 5600 D
One of the four lights along the top front of my TC has a burnt-out bulb. I've not yet pulled the bulb to see what type it is. Would anybody know if it is a standard (i.e. you can find it at NAPA) bulb...or a Bobcat-specific part?
Also...One of the the two driving lights on the front has a burnt-out bulb. Same question as above.
Thanks in advance for any help.
It turns out the headlight bulb is a halogen bulb made by Osram/Sylvania. Their part number is 0-7951. There are three terminals on this bulb...the TC wiring harness only supplies two wires to the headlight housing and the housing has a three-wire harness to the bulb. Makes me wonder what the third terminal on the bulb is for (extra output/high-beams??).
As I searched the web, there was great variation in price for these bulbs...from $2.80 to around $16 each. :eek:
/ Headlight bulb type(s) ?? #3
Spudgunner,
I few years back I had a couple of those bulbs burn out. If I remember correctly, when I picked up replacements I was told 'not' to touch the new bulbs with bare fingers or they may burn out quickly...
Spudgunner,
Yep...all the halogen bulbs I've dealt with in the past had a warning on the packaging about touching the bulb. The bulbs I just received didn't have that warning...but I'm sure it's good advice.
Also... There may be a couple of hacks to the stock TC headlight wiring that would throw some extra candlepower out the front. These headlight bulbs do indeed have a "hi-beam" circuit; hence the three terminals at the back of the bulb. The stock TC wiring harness runs power and GND to the headlight housing. The housing has an *internal* wiring harness featuring three wires...one of which is unused according to Mr. Multimeter. This unused wire appears to go to the hi-beam terminal/filament.
The first mod (and biggest bang per buck, IMO) would be to simply splice the unused/hi-beam wire into the lo-beam lead of the headlight. Amperage draw in this case would jump from 3.3 amps/bulb to 3.7. This according to Don's Bulbs (donsbulbs MAIN PAGE - rare specialty bulbs projector lamps). The TC harness should easily be able to handle this. The wiring harness internal to the headlight housing has lighter-gauged wires...but my SWAG is that they'd be just fine.
The second hack would be to run a separate hi-beam wire to the headlight housing. I suppose one could then control the hi-beams by a separate switch or whatnot.
FWIW... I ordered my bulbs via the i-net from Translectric, Inc. The Heavy Duty Parts Pros and they were 2.38/each. This is the first time I've ever ordered anything from them.
Disclosure: I have not tried either of these mods. I intend to implement the first mod when I have time (that usually means "this spring"). Be careful. Don't melt stuff or let the smoke out of anything.
/ Headlight bulb type(s) ?? #5
I dont know the part number conversions off the top of my head for the bulb type (H7, 9005, 9004 H4 etc,) but i could get them for you on monday. If available, you could run a silverstar ultra bulb and get much better performance.
/ Headlight bulb type(s) ?? #6
Spudgunner,
Please let me know how they work out. If memory serves me, I paid 'thru the nose' for the bulbs at the Dealer...
Tim
Spudgunner,
Tim
Update: The brand of the bulbs is Hella and they're made (IIRC) in Romania according to the box label. Hella is a very well known brand...but time will tell.
2018 Isuzu NPR Cab and Chassis Truck (A59230)
2018 Isuzu NPR Cab...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
(APPROX. 20) 4' X...
2008 TOYOTA Camry Solara Convertible (A59231)
2008 TOYOTA Camry...
Rotary SPOA9-200 Automotive Lift (A59230)
Rotary SPOA9-200...
