Quick easy electrical question
/ Quick easy electrical question
The poor OP is going to sit there drooling on himself sifting through all this nonsense.
Oh man, I blurted out a loud laugh when I read this the other day,
was thinking to myself, well, it probably wouldn't be the first time.
Anyway I finished up this simple install. Just upped the fuse to 15 amp put a switch on the panel on rt fender in a blank spot, bought a lit rocker switch for $6. at auto zone. JD wanted $45. for a switch to fit that slot.
Ran some 14ga wire, well this is kinda the hokey part, seems auto wire doesn't come in a cable like house wire 14-2 etc. and since I needed power and ground to the light as I couldn't trust the ground on the canopy frame mounted to folding rops, I just went to Home Depot and got some 14-2 stranded wire it's in a decent plastic sheath.
I know there's probably a few reasons why this is wrong but seemed easy at the time.
This circuit is hot to the switch and to an accessory outlet all the time, so I am concerned about a short with the wire running under the machine and over the rear end. I may put a cut off switch on the dash to kill that circuit when not needed.
http://www.rykersafety.com/abl-1500-twin-halogen-work-lamp.html
These are the lights , thought they might of cost more, they do put some very nice light.
Thanks everyone for the help, JB
/ Quick easy electrical question #22
That what I do. I think it is safer than single wire due to double insulation that is also thicker.
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
New/Unused AGT MX-CRT23 Mini Skid Steer (A61166)
New/Unused AGT...
Dodge Charger (A56859)
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A61568)
2020 Broyhill Load...
2015 Lincoln MKC SUV (A61569)
2015 Lincoln MKC...
