bucket lifting problems
/ bucket lifting problems #1
RogueFishr
Southern Oregon
Kioti CK30
I have a Kioti CK30, with a problem that is getting progressively worse. When I pull back on the stick, to raise the bucket with a load in it, it lowers. If I pull back more, it will finally reverse and raise the bucket. If I stop, the bucket will slowly lower itself. If I try to raise it again, it will drop rapidly until i pull the stick back far enough. Is this something in the control valve? Or is it a pump problem? It worked fine, until this summer, and has been getting progressively worse. I am trying to save some money by figuring out what this is and replacing / repairing it myself.
Thanks for any help.
RF
/ bucket lifting problems #2
RF
Your control valve need a check valve in "parallell gallery"....or maybe better said that you need a new control valve that have this check valve!!
see red circle on my picture of a basic hydraulic system
Thanks for the reply. I will look into getting a new check valve. I may take mine apart (once I know I can get a new one), and see how it works.
Thanks again,
RF
/ bucket lifting problems #4
OK, cool!^_^ I just wanted to make sure I didn't do anything wrong :]
Nice! I'll start saving up some scratch for this:eek:
/ bucket lifting problems #5
Thanks again,
RF
If there is a check valve in your controlvalve....not all control valves come with these check valves....this check valve will secure the load from dropping from gravity, when operating the control valve....for example a log splitter valve don't need this checkvalve because there is no load pressure from gravity, that tries to push flow backwards....
I don't know if your bucket function ever have been normal. If so there is a check valve in your control valve, and it is possible it have jammed in open position...
Can you send pictures of your control valve....these check valves are usually located under a plug between the ports.....
/ bucket lifting problems #6
I believe that just about all valves designed for loader work have internal check valves to keep the load from dropping when shifting the spools.
/ bucket lifting problems #7
Loader valve with load check valves
splitter valve, No load check valve
If a splitter valve is used on a loader, it will act like posted.....
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
2011 JCB 4x4 Backhoe 3CX14-4-T (A65579)
2011 JCB 4x4...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
