Can't load my tractor!
/ Can't load my tractor!
I still say a hour with me and my welder and I could make the ramps that are on it work by adding 3' to each of them. Cost you very little and will be a final solution to all your trailer problems both today and in the future for loading other equipment like cars.
Unfortunately, a 3' addition to the ramp length will make no difference at all.
JayC
Had to load and unload mine today. just some scraps of wood managed to get me off and on.:D
That's close to what I am doing, but I need considerably more plank height.
JayC
/ Can't load my tractor! #63
JayC
I do not see why? I don't think you are looking at this right. I built a set of 10' long ramps for a friend when his man lift would not load with 6' long ramps and it worked. It significantly cuts down the angle of the ramps by adding length.
Chris
/ Can't load my tractor! #64
please start....my truck weighs 7,600 lbs. My ramps have supported it just fine. I can't learn anything if nobody explains it to me....I am 60 years old, I don't have enough time left to make all my own mistakes....:eek:
To start with getting a trucks rear wheels to climb ramps will be tricky pulling a trailer(open diff wont help). Second when the tractor gets on the trailer it the only wheels that hold in park or with parking brake are trucks rear wheels unless its in fwd even with trailer tire blocked it will move some and will still take weight off the truck tires. And when it does move it will fall of one ramp then is when the fun begins.
Not wanting to disagree but I have done wrong enoght that my pucker factor just got really high when i read your idea not that it won't.
Find a ditch theres always one within 1/4 mile, a short drive and asafe way to load or unload.
/ Can't load my tractor! #65
It wasn't my idea, it was someone elses but it sounded o.k. to me.:confused:
My truck will climb my steel ramps all day long without a problem. Pulling an empty trailer won't make any difference.
If I was doing this I would back up on them to make getting them under the truck and the truck off the ramps easy.
If the rear of the trailer is blocked so it can't go down by the bottom of the ramps or additional blocking I don't know how it will take any weight off the truck since it won't be able to lift the front of the trailer up. We aren't talking about blocking the wheels we are talking about the blocking that is built into the ramps to stop the trailer from dropping, or additional blocking as required at the rear of the trailer.
I fail to see how anything could move under these conditions.:confused:
I have used my portable steel ramps many times in the last 20 or 30 years and I have never put myself in a position that I had a problem.
A ditch is a good idea but the poster wants to be able to load and unload where he needs to not where it is possible by natural terrain. The ramps are the equivilant of having a portable ditch. Also if he only has a 2 wheel drive pick up there is no way he is going to pull 8,000 lbs out of a ditch, yet going down hill on the ramp will not be a problem.
I still think the use of ramps is a good and economical idea. Please convince me otherwise.
I think you didn't catch the part of blocking the rear of the trailer. If only the wheels were blocked you are right it could unload the rear wheels of the truck.:eek:
If it was my truck it is so friggin heavy it wouldn't make any difference, but that is not what we are talking about. By blocking the rear end of the trailer it makes it fool proof. The man has a 6K# tractor and a 10K# trailer. I think he is good to go.
I don't think loading a tractor under these circumstances would generate much U-tube interest. You just drive it up the hill, tie it down, drive off the ramps, throw the ramps in the back of the truck and have a great day.
That has been my experience........:D:D
If I am missing some other hazzard please explain.
/ Can't load my tractor! #66
JayC
I think you are wrong. My CK20 with the subframe backhoe was dragging using the 5' ramps that came with my trailer. I bought a set of 7' ramps and that took care of my dragging problem. Longer ramps give you a shallower approach angle which keeps the rear of the tractor off the ground.
/ Can't load my tractor! #67
By the time it gets figured out on here he could have drove it there and back twice.
My new vote $7 SMV.
/ Can't load my tractor! #68
May I suggest doing several (or all) of these things:
1. Come up with some cribbing for both the rear of the truck and for the ramps (extend it what you can). Yep, look Craigslist over or knock on your buddies door for some lumber.
2. Dig a hole for the trailer wheels. I had to do this for my truck to use an existing ramp at my house. You have the BH -- use the force!
3. Extend your stabilizers some while loading/unloading. Lowers your tilt/pucker factor.
4. Have a load of dirt delivered to the new place -- surely you could use some road base or recycled concrete anyhow? A good driver can spread it pretty well for you.
I have these issues with my 16' flatbed and my wifes little minsteer (NH L125). Or trying to load my Miata. Takes two 8~10 foot 2x12's and several heavy blocks (of varying sizes). Got any large logs you can square (or angle one side to match the slope of the ramp)? And even then I park using the ground as my friend.
Or: rent a trailer or pay a local towing (or equipment rental company) with one of the sliding ramps to move it. They are likely not too busy this time of year/economy.
/ Can't load my tractor! #69
Also leave the trailer hooked to the truck but use the tongue jack of the trailer to lift the rear suspension of the truck and lower the rear further. Once you get the tractor past the tough point, raise the jack.
Ken
/ Can't load my tractor! #70
If the conditions are right the hoe can be used to dig a trench just where it drags when unloading. After the work is done and the hoe is loaded it can be used to fill in the hole!:D:D
/ Can't load my tractor! #71
Ding, Ding, Ding we have a winner.
Chris
/ Can't load my tractor! #72
We solve similar problems with a shovel.
Dig holes that you can back the trailer wheels into. On the loading end, you can use the hoe to dig a pair of parallel trenches a few inches deep that will lower the rear of the trailer. On the unloading end you will need a shovel, but it is only a few minutes work.
Pulling even the loaded trailer out of the holes with the tow vehicle is not a problem if you shape them sort of like a ramp.
For a "few times per year" this is the least costly and safest solution you will find.
Chris
Sorry Chris - the part of the geometry you don't understand is the ratio of wheelbase to the portion of frame that is hanging off the back, which is roughly 2:1. I have about 6" of ground clearance, so as such, the front of the tractor can never rise more than a foot above the rear tires. With my 6' wheel base, and 2' trailer, the only way to solve the problem with a ramp extension is with a 12' ramp. Ding ding, indeed.
JayC
/ Can't load my tractor! #74
Well then make them 12'. Like I said I just made a 10' set. Its your only real everyday option. The other suggestions will work but require being at the right place at the right time with a ditch, wood, ramps, a case of beer, ect.
Chris
/ Can't load my tractor! #76
I still say the ramps do not need to be 12' long if you back it on. Adding 3' would surely solve the issues. Just as long as the ramps are the same length or more as the wheel base of the tractor. Loading by backing on is your answer.
Chris
/ Can't load my tractor! #77
Jay
I am not trying to be a jerk here. I am trying to give you the $100 solution. I went back and re-read all the post and many are on the lengthen the ramp band wagon. It is the only real solution. Make the ramps 1' longer than the distance from the rear tire center line to the back of the backhoe. Once this is done you will be able to BACK THE TRACTOR ON and prior to the hoe hitting the rear wheels would be 1' up the ramps and would allow it to clear the trailer deck.
Trust us on this one. We are trying to help here. If you lived near me I would do the work for free just to prove it would work. I went through this this spring with my friend with a man lift who was going to drop 5K on a tilt trailer to haul a man lift for his garage door company. We built 10' ramps to replace the 5' ramps and it did the trick. Yes, they are long but cost him very little to solve this issue and a couple of his extra springs to the ramps make lifting them a 1 finger job.
Chris
/ Can't load my tractor! #78
Diamondpilot: I'd also do the work for free. I don't think he relizes how much even a short extention would make much less doubling what he has. From the picture that was posted, those ramps are way to SHORT! If he wanted a 12' ramp{probably way more then needed} he could have it hinge at 6' so that it would not stick up so high. As others suggested, extend the ramps then back onto the trailer?
Digging is fine if your not worried about the ground where you're at or about getting stuck. I would not want to have to dig a hole every time I needed to load or unload though. Why not fix it right the 1st time.
I'd go talk to some folks that have BH's and trailer and check out there setup. Honestly I think your making a mountain out of a mole hill ;) I'm not trying to be a jerk here either, like the others just trying to help.
/ Can't load my tractor! #79
OK, guys. I said it once before...I'm not a fan of speculation.
So I built a simple replica of the situation in AutoCAD to demonstrate the problem and a couple different solutions.
I used fairly conservative parameters based on the OPs input and information available online. I put the deck 24" off the ground (Hudson says 23"). I assumed stock ramps are 5' long. The wheelbase of his tractor is 71", but I put in 72" (even 6 foot). I made the rear-most tip of his backhoe 3 feet behind the rear-most point of his rear tire and put that corner a mere 6" off the ground.
From my model, you can see that even if the stock ramps were extended to 10 feet long (which I wouldn't want to lift or have sticking up during transport), it wouldn't come close to working. I don't even think 12 foot long ramps would work IF they are hinged at the trailer deck.
He needs "sub-ramps".
By my calculation, sub-ramps that are 10' long (properly positioned) or 8' long with a "ledge" at the lower end at least 3 inches tall will allow the point of the backhoe to swing harmlessly in the air as the tractor is loaded.
As I stated before, I have the identical problem, albeit on a smaller scale with my little BX tractor/backhoe, and this is how I solved it. But my sub-ramps are only 8 feet long and could be a little shorter.
I hope everyone finds this information helpful to the discussion.
Even more, I hope the OP tries it with a few 2 x 12s and tells us that it works!!!
/ Can't load my tractor! #80
I think if you raise the front of the trailer about 14"-16" by driving up on a set of ramps with the rear tires of the truck, the rear of the trailer will drop 7 or 8 inches. That along with a slightly extended ramp or a little cribbing to drive up on (sub-ramp) might just do the trick.
If you take you example that is third fron the left in the top row and draw a line from the contact point on the ground to the top of the end of the trailer, that will give you the length of ramp that will work. If you then drop that top point 8 inches and draw a line parallel to the first one that will give the length of ramp that you need with the tuck up on ramps. It may be close to what the standard ramps are.
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2022 Forest River R.pod Towable RV Trailer, VIN # 4X4TRPV28NR208064 (A61166)
2022 Forest River...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
2000 Freightliner FL112 T/A Dump Truck (A61568)
2000 Freightliner...
