Can't load my tractor!
/ Can't load my tractor! #81
I think if you raise the front of the trailer about 14"-16" by driving up on a set of ramps with the rear tires of the truck,
I certainly didn't factor that into the analysis. Personally, I would never consider this as a viable solution under "normal" circumstances for a variety of reasons. Not the least of which is convenience.
Remember, to do what it is you want to do, you'd have to whack off the "ramp supports" that help hold the rear of the trailer up while loading and keep the full lever-action of the loading procedure from coming to bear as negative load on the tongue.
I would not (nor would my wife allow me to) put the back of my truck precariously on a set of ramps while loading an extremely heavy tractor that, without the ramp supports, would further lighten the rear of the truck. In the best of conditions, this is very dangerous. Put it on a gravel driveway or in a field and it is pure insanity.
I am 100% confident that a 10 foot sub-ramp, positioned as shown, would allow him to safely load and unload his tractor. Since I'm devoting my workday to this silly exercise and I bill myself out at $100/hr, I now have something around $200 into telling the OP that my solution will work.
The other advantage to my solution is that you can then unload stone/mulch/whatever using the tractor without removing the backhoe. To further my point on putting the back of the truck on ramps, I wouldn't do that with 2 tons of stone in the trailer, either.
/ Can't load my tractor! #82
81 post of bantering about the trailer haven't gotten us very close to an obvious solution. Is there some way to modify the backhoe to raise it the distance needed? Maybe rather than raise it Jay could tuck it in closer to the rear of the tractor.
Is it subframe mounted or 3 point mounted?
/ Can't load my tractor! #83
I think he said in an earlier post that his ramps didin't reach the ground the way his hitch is set up now. I would not suggest wacking them off, just letting them reach the ground to do the job they were intended to. If the rear of the trailer is supported there is no issue with lifting the front of the trailer. I agree that a paved surface is the only place that ramps could be used safely. I have used them 30 years without incident. Extending the ramps on the trailer is the best option, but it isn't the only way to do it a couple times a year.
/ Can't load my tractor! #84
The trailer is to small to hold anything but the tractor, no room for stone.
O.K.
I have a question for you that will only take you 1 second to find the answer to using Autocad
"If you take you example that is third fron the left in the top row and draw a line from the contact point on the ground to the top of the end of the trailer, that will give you the length of ramp that will work."
What is that Dimension?:confused:
It looks to be around 12 foot, you could then hinge it in the middle as DiamondPilot suggested, extending the origional ramp only 7 feet, saving on materials
/ Can't load my tractor! #85
OK, guys. I said it once before...I'm not a fan of speculation.
So I built a simple replica of the situation in AutoCAD to demonstrate the problem and a couple different solutions.
I used fairly conservative parameters based on the OPs input and information available online. I put the deck 24" off the ground (Hudson says 23"). I assumed stock ramps are 5' long. The wheelbase of his tractor is 71", but I put in 72" (even 6 foot). I made the rear-most tip of his backhoe 3 feet behind the rear-most point of his rear tire and put that corner a mere 6" off the ground.
From my model, you can see that even if the stock ramps were extended to 10 feet long (which I wouldn't want to lift or have sticking up during transport), it wouldn't come close to working. I don't even think 12 foot long ramps would work IF they are hinged at the trailer deck.
He needs "sub-ramps".
By my calculation, sub-ramps that are 10' long (properly positioned) or 8' long with a "ledge" at the lower end at least 3 inches tall will allow the point of the backhoe to swing harmlessly in the air as the tractor is loaded.
As I stated before, I have the identical problem, albeit on a smaller scale with my little BX tractor/backhoe, and this is how I solved it. But my sub-ramps are only 8 feet long and could be a little shorter.
I hope everyone finds this information helpful to the discussion.
Even more, I hope the OP tries it with a few 2 x 12s and tells us that it works!!!
Very nice work Keith. The issue is I said he would have to back up the ramps and onto the trailer. Can you run some models that way with say adding 2' to 3' to the factory ramps. Remember that the BH will fit in between the 2 ramps so all that will be a factor is the trailer deck.
I could see in my head that pulling on forward was just not going to work without mile long ramps since his BH extends 3' and is only 6" off the ground.
Chris
/ Can't load my tractor! #86
I though about that also but then his dig depth would suffer and the outriggers would probably not touch.
Chris
/ Can't load my tractor! #88
Hmmm, How much lower can he get the back of trailer down? with trailer still hooked up to truck and jack it up, wouldnt the back go down at leat 2 to 5 inches? I still think using hydraulics to do the work for you is the best thing to do.
Why not drive the truck rear tires on couple of 2X12's? jack up the trailer still attached to truck as far as you can . put a couple 2X12X12 under the ramps. Drive tractor up. I betcha by this time you might only need couple more inches more to get tractor on trailer. Just get outrigger down, use the BH bucket to push up 2" up and in. done!.
This seems so perplexing that it can't be that difficult to get it on. perhaps the OP can take a video and post on youtube ?
/ Can't load my tractor! #89
I dont have auto cad or even a manual cad :D.. Seriously I had the exact same problem with my Kubota L5240 and woods BH95. I had removable ramps I think they where 5' I made some redneck ramps out of 2x6's with a 4x6 stacked they had rope handles and work fair. By ramps I mean they laid flat on the ground the added height of the 2x4 and 4x6 atop each other.
I found myself trailering my tractor more and more after a few near misses with the board cribing a buddy offered a fix easier on the back and safer.
He added 3' and mounted the ramps to the rear of the trailer with a spring assist. It is the best thing I have ever done to the trailer the approach and departure angle very much better and no more b/h dragging.
Digging a hole is a great idea if you are seldom going to have to trailer it. I dont advise loading with trailer disconnected done it once did not like it.
Anyhow they do stick up rather high and are somewhat fugly but they work great..
Good luck which ever route you take.
/ Can't load my tractor! #90
Chuck your fix is just what I am proposing. I still think he will have to back on but we did the spring thing also on the trailer ramps I modified using stock garage door springs. He can put the ramps up with a single finger.
Chris
/ Can't load my tractor! #91
Disconnect the BH. Lift it on the truck with the loader. Drive the tractor on the trailer. Done for now.
Sell the trailer and get one that works.
/ Can't load my tractor! #92
Agreed, but I would place the sub-ramps under the trailer ramps. Stagger the 2x material ends to create steps. Nice job with the pics, could we get a short 3d modeled video too? :D
From the OP pics., backing onto the trailer won't work. The hoe boom will hit the front edge of the trailer and tongue weight (if any) will be minimal. Chaining the ramps to the loader bucket would be time consuming too.
/ Can't load my tractor! #93
I give up. You cant help when its not wanted.
Chris
/ Can't load my tractor! #94
Straight ramps...no sub-ramp, pulling forward...the ramps need to be 20 feet long, all else being equal.
Backing on, it looks like 9 foot ramps would work with the BH clearing the trailer deck between the two ramps.
Someone else loads the stone at the quarry. I'm just talking about unloading it at the homestead using something other than a shovel.
/ Can't load my tractor! #95
With my budget for a couple of time a year move ,
I would add onto the ramp , but if thats not possible I would use the hitch jack or another jack to raise the bed some, and then pull it up till it hits and set the outriggers out just in case. but not touching the ground then use the bucket to push it up on , pull forward. and then raise the riggers, (all safe). Chain it down and go.Ive done stuff that was far more hair raising on the 'ground' at least on a trailer I would have a more secure feeling.
OK All - it's done. 4@ 2x10 planks made into a sub ramp, that reduce in 6" increments from 5.5' to 4' long. Blamo. I put handles on the ramps so that I can lift/carry them too. Thanks for all the suggestions and spirited debate.
JayC
/ Can't load my tractor! #97
JayC
Looking Good.
When you get a chance, flip your stinger. I think you'll find the extra few inches makes a comfortable difference too.
Yes, I planned to do that, but couldn't get the ball's nut (ouch) off. I figure if I could load the tractor leaving the ball 3" low, I'll just have that much more margin in my solution. I'll get a new receiver/ball as soon as I get a round Tuit.
JayC
/ Can't load my tractor! #99
ON EDIT:
Didn't notice that the job was done, until after my post. Picture looks good. Glad it worked out all right.
Unfortunately, a 3' addition to the ramp length will make no difference at all.
JayC
Hate to disagree, but done properly (as I KNOW he would), it would indeed make a difference. The difference being the height, not the length. Simply dove-tail the ramps so it can climb sooner. Might consider adding the extra 3' at the front of the ramp, instead of at the end. That would allow you to control the angle that it hits the trailer at, when it arrives at the trailer. As long as the rear tires are on the ramps, when the ultimate height is reached, it is do-able. Seems you mentioned ramps 4' plus the 3' gives you one more than is required, at 6'. Did I miss something?
Putting a block under the landing gear and taking some of the slack out of the truck suspension might give you an inch or two at the rear of the trailer.
If you lived near here, I could fix the ramps with my welder in 59 minutes, instead of an hour. (just kidding, probably take me an hour to get set up, lol)
Dove-tailing the rear of the trailer isn't as bad as it sounds. Probably half a days work to do it, plus painting.
David from jax
/ Can't load my tractor! #100
Do I see ramp 'feet' on your trailer ramps ?
If you raise the front of the trailer, are you still going to be able to drop ramps with those 'feet' ?
The way to solve a problem like this is to set the ramps down so that they rest on the feet (if neccessary) and then back up the trailer so that it "pops" over the feet. Then, when loaded, drive forward, and put up.
Kyle
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2007 Ford Taurus Sedan (A61574)
2007 Ford Taurus...
44in Hydraulic Grapple Bucket Mini Skid Steer Attachment (A61572)
44in Hydraulic...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
