Rake Power Rake Deflector/Rubber Barrier Question
/ Power Rake Deflector/Rubber Barrier Question #1
Spudland_Dave
Maine
Deere 3520 Cab, Deere F935
Putting the final touches and "attachments" on my power rake and was wondering about the rubber deflector/barrier.
Common sense (for lack of better terms) has me thinking this is a "set it and forget it" thing...Why would a person want it opened up all the way? I've tested out the rake with NO barrier, and I honestly dont see why a person would use the rake like that?
Where I'm going with this is should I make the deflector in a fixed position or adjustable...obviously fixed is easiest, adjustable has a bit more added complexity..
/ Power Rake Deflector/Rubber Barrier Question #2
with the barrier open, it will let larger objects through. With it closed it gathers all of the debris in the box. So, if you wanted to "sift" out the larger rocks from you material, leave it down.
I must admit i'm a "power rake noob"...but I thought that was the whole point of a power rake.....
I guess I should ask...when would you not want to sift the material?
/ Power Rake Deflector/Rubber Barrier Question #4
When I'm doing an area that's real heavy with rocks, I'll make a pass to get the rocks more than fist size, clean them up, then make a second pass with the deflector closed down to catch the smaller trash. I like mine adjustable, but I don't change it much. Harley brand used to have a hydraulicly adjustable deflector. Mine's a Landpride.
2025 Safety Basket Forklift Attachment (A61572)
2025 Safety Basket...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2013 TIGERCAT 720E FELLER BUNCHER (A64276)
2013 TIGERCAT 720E...
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
