M7040 performance?
/ M7040 performance? #1
manitouofthehatchie
I'm thinking of buying an M7040 w/ loader and spear to move round bales of hay and doe maintenence work around my cattle farm. Been using an old '67 JD4020 but want to upgrade to a cab model. Any input on the 7040's working capacity would be appreciated greatly. I just want to be sure it's enough tractor as it is about 30 hp less than the old 4020.
/ M7040 performance? #2
will this be a back up tractor or the primary tractor for the hay operation? what's the pto hp requirement of your baler? (7040 pto is 62). it should work fine for moving bales, but I'd strongly look at the 85/9540 for anything more. lots of 95's around doing hay. the jump in equipment & capabilities from 70 to 85/9540 is considerable. in any case load the rear tires (or cast) and definitely get the hydraulic shuttle over the dry clutch for your kind of work. the 12 sp. hd tranny in the 85/9540 also increases the 3 pt. hitch to 7600 # best of luck bb
/ M7040 performance? #3
My 7040 works quite well, thank you very much.
You might want to go to the Kubota website and do a side-by-side comparison of the 7040, 8540, and 9540. There is quite a price hike when going to the 8540/9540.
If the JD4020 was doing the job the M7040 should be no problem. The difference between the HP of a well-used '67 JD may not be that noticeable with a new tractor. Be sure to try one out at a dealer if one is nearby.
Thanx for your reply- won't be baling though- just moving it. I have it bailed on the halves. Dealer said it would haul one front and back but I wasn't so sure.
Ah! An owner! Great! Has your unit had any major issues? No problems handling and hauling weight?
/ M7040 performance? #6
having owned the 7040 and now 85, the 70 by all means should work great. if however there's even a small possibility that you might do your own hay or expand one day, I'd look at the bigger model. as it stands, you'll be well satisfied with the 70....wise choice with the m series. all the best bb
/ M7040 performance? #7
No problems at all with the M7040. The FEL is quite strong. The LA1153 is rated to lift 2535 pounds to the top of the lift but I have lifted a 4000 pound (estimated) stump about two feet off of the ground with the forks before the hydraulics stalled. With loaded tires and a 1000 pound counterweight the rears would just scratch the ground with that load. 4WD solved that problem. The auto locking front differential helps quite a bit as well.
The 3PT will lift 3307 pounds. Having a bale on the rear should provide a counterweight for the FEL. The most I've had on the rear is a 2000 pound disc so have never reached the limit.
The turning radius is amazingly short for a tractor that size and runs circles around my old L3650DT-7. The hydroshuttle syncro transmission is nice for loader work but I haven't completely mastered it yet enough to use it confidently.
/ M7040 performance? #8
I've had my M7040HD for 2 years next month (just got my post card from Kubota trying to sell me an extended warranty) and haven't had a single maintenance issue-other than my doing the routine scheduled service as required. Got iron rims and filled tires. Don't run it a lot-only 180 hours so far, but spend a fair amount of time aggressively using the bucket and a Woods 7200 in heavy brush around the edge of our meadow trying to reclaim some extra land. Also move a lot of dirt and gravel and quite a bit of stone. Pulled some pretty good sized log lengths out of the woods, hauled a lot of firewood, pulled the box scraper with ease even when full of gravel-BUT, I never hauled any hay.
Much obliged bb! Also found a 2001 M9000 at what I think is a decent price, about half of the new 7040 w/ more hp andfairly low hours, three remotes.Any thoughts?
Many thanks guys. I feel better now. Will repost when I decide which way to go!
/ M7040 performance? #11
You will really like the three remotes.
/ M7040 performance? #12
Two years running an M7040 also with cab absolutely love it get the ag tires and filled, get the CI hubs rear and get wheel CI weigths to provide stability 4 wheel drive is the way to go as well Use of rear counter weights will make it light footed in the front and is recommended to ease the wear and tear on the front end also I would get the air suspension seat for comfort
/ M7040 performance? #13
No maintenance issues at all. We use ours quite a bit - only a year old or so and have over 400 hours on - 95% loader work. Handles really well, good turning radius as was suggested and lifting capability.
/ M7040 performance? #14
My M5700 has no problem with round bales on FEL and 3 point. even with just a bale on the FEL and nothing on the 3 point it does not feel like it is unbalanced. No issue on rough ground either. Can barely tell it has a load. I do have r4's don't know if that helps or not. I can't imagine the tractor your looking at not doing even better.
/ M7040 performance? #15
Recently I went shopping for a M7040 but bought a New Holland instead. Though I liked the 7040, Kubota is not offering cash incentives while NH if offering very good cash incentives.
For about the same money, I got more HP, twice as many gears, better hydraulics, much more weight and a few other options. I would look over the specs of the T40xx series side by side with the 7040, find what suits you and call around for pricing.
SDT
/ M7040 performance? #16
SDT
Okay, you piqued my curiosity. You say you bought a NH T4050 16x16 power shuttle with 80 PTO HP and Supersteer for about the same price as the Kubota M7040 and you got cash back? What other options did you get? That sounds like quite a deal, can you provide more details?
/ M7040 performance? #17
My dealer sells both NH and Kubota. The T4050 Deluxe that I bought was on the lot and he had it for several months, though it is a 2009 model.
The T4050 Deluxe comes with a cab, which I did not really want. I was looking for a M7040 Kubota open station but simply could not pass up the deal that I was offered on the T4050, cab or otherwise. The T4050 also has Supersteer, which I definitely did want for maneuverability. I drove a T4030 without Supersteer but it would not turn closely enough for me, nor would it turn as closely as the M7040, which has vertical pinions rather than CV joints. This is the feature that initially attracted me to the Kubota.
My T4050 also has dual remotes, a mid mount valve with joystick, and the tractor was advertised with a "free radio." I was not looking for a radio but it retails for around $300 so I took it rather than taking the significantly lower dealer cost deduction that I could have taken.
I also bought a front weight package (6 weights and bracket), 4 rear weights, arm rests, dual outside mirrors, an 820TL FEL with third function loader valve and a Kasko snow/material blade for the FEL.
Ignoring the FEL and blade, my dealer told me that he could not spec out a 62 HP M7040 with cab for the price that I paid for the 80 HP T4050 with weights, radio, third function loader valve, arm rests, mirrors, etc.
The current NH incentives expire on 11/30 but nearly everyone expects that they will be replaced with new incentives that are at least as attractive.
It is my understanding that Kubota offers attractive financing terms, similar to those offered by NH but no cash incentivevs, while NH offers either one or the other (not both). I took the cash as discount against the price and wrote a check.
SDT
/ M7040 performance? #18
I have a '07 M7040. I abuse it. Rough ground and steep hills. Dragging, bushhogging, lifting, digging, etc. This tractor hasn't missed a lick. I follow all recommended maintenance and check it after each usage. I've had no problems. It starts, runs and works without any fuss. It will do an amazing amount of work. You will need weight in the rear wheels. I use ethanol. I also suggest tubeless tires for ease in repairing punctures on the go.
2015 Grasshopper 725D 72in Zero Turn Commercial Mower (A68183)
2015 Grasshopper...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
1995 Jeep Wrangler 4X4 SUV (A66738)
1995 Jeep Wrangler...
2005 FORD TAURUS CAR (A66091)
2005 FORD TAURUS...
