Electric diverter..
/ Electric diverter.. #21
Here are a few pics of my installation, it shows my joystick mounted momentary switch, dashboard mounted toggle that is wired in parallel and the last ones of the valve mounted on the FEL and quick connects on the cross tube. If you need any info on how I wired or plumbed my setup just let me know.
/ Electric diverter.. #22
Funny question Kenny!! When I went to order this I remember you saying one was better than the other, so I went back to the first page. Then Re-read your post on which one to buy and clicked the link you had posted for the A model. Then just purchase the one the link sent me to.
After just re-reviewing my order, the links you had posted both go to the non-A version. No big deal, looks like i bought the regular one, not the A version.. :) Might want to edit your post if you can so in case some else clicks it they get the recommend one.
I have the 5117 model..
Thanks
--Craig
Whoops! Can't go back and edit now!
Just as the diagram shows, you want a SPDT or DPDT switch, but of the Momentary pushbutton type. That way one solenoid will have power without touching the switch, and the other will have power when you press it. Here are some examples:
Push Button
Push Button
/ Electric diverter.. #23
I am disagreeing with you on this. If no voltage is applied on the switch as outlined on the electrical schematic, the FEL valve will relieve. In the normal mode, curl function, the curl solenoid would be energized. When you use the grapple, the switch is flipped the other way, and the grapple is now in the circuit. If you are going to be operating a grapple all day, would you be pushing on a switch to operate the grapple. Just lock the switch in the grapple position and leave it there until you want to use the curl function.
/ Electric diverter.. #24
I guess your talking to me?
It is correct that if there is no power to either solenoid then no fluid will flow.
An SPDT or DPDT momentary switch WILL work fine. You cannot use just the grapple all day, you have to use the dump/curl as much or more than the grapple.
For safety reasons IMHO the system should default to stock condition, hence the use of a momentary switch.
Thanks agian!
Thats what i was missing, i was looking at the wrong momentary switches, they only had two connections.. Makes sense now, wiring should be straight forward. Thanks agian..
/ Electric diverter.. #26
Thanks agian!
You are welcome!:D
/ Electric diverter.. #27
Sorry JJ,
Having used a fair amount of equipment to grab things with a 4in1 bucket on a loader (similar to a grapple) I have to agree with Kenny on this one. This is one usage that a way to mount a button on the joystick which could be opperated with your thumb would be very handy!!
/ Electric diverter.. #28
A quick question for DonT as I don't want to digress off topic too far. Did you make the cross brace for your loader uprights? I've been thinking about doing the same for my JD.
OK, back on topic. My preference on the valves would be the -A series from Surplus Center as the normally off position would be for the loader while the 'on' position would be for the grapple. The advantage to this is that power is only being applied to the solenoids for a secondary function. This saves on amps and solenoid wear. The non -A series needs power regardless of which way you are diverting the flow.
/ Electric diverter.. #29
No the brace is standard on my Kubota
I also agree with the thumb operated pushbutton, I have both a toggle on the dash and push button on the joystick wired in parallel. I don't think I've ever had an occasion to use the toggle. The Hurst shifter knob with NOS button works perfectly.
/ Electric diverter.. #30
The problem with that Hurst shifter switch is that it is a SPST correct? Your valve only needs power to divert wheras this valve we are talking about needs power to one or the other solenoids at all times.
/ Electric diverter.. #32
I used a relay so that when the switch is open the relay suplies power through the NC contacts, push the button and it goes through the NO contact
So Don do you have the A version?
/ Electric diverter.. #34
Either valve will work as long you apply power correctly.
/ Electric diverter.. #35
I guess, mine is actually the Fasse version, it looks identical though, but I need power in both directions. It works like a charm you just have to get used to the re-gen feature of the Kubota FEL valve, when moving to the right you have to go beyond the detent or it works the same as going to the left
JJ - I understand that, tyring to get an example of proper setup.
DonT - Sounds like you have the same valve as me, as i'll need power in both direction also, but i would like to use that same Hurst shifter you used, i like the idea of having i built right in.
So could you tell me more about your wiring, with a the relay setup?
Thanks
--Craig
/ Electric diverter.. #39
As I said I actually have a toggle and momentary wired in parrallel, i never use the toggle but I would probably still wire it in, you never know what might come up.
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
500 Gallon Hydraulic Oil Holding Tank (A61573)
500 Gallon...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2020 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 MACK ANTHEM...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
