Gator XUV, 2009 vs 2010
/ Gator XUV, 2009 vs 2010 #41
Just thought a few of you would enjoy looking at these...
Any more pics? Did you get to drive one? Can you give some info on what they upgraded?
Thanks for the pics!
/ Gator XUV, 2009 vs 2010 #42
The 4 seater that I was told would be there was not. I imagine it still is a year or two a way. I drove the new 825 and it is very good. The only thing there that compared on power and ride was the Kawasaki terex. The Ranger was a close second. The honda big red was a disapointment. I expected better from them. Back to the 825. It was very good all the way around. The only reall beef I had I wish the clutch had a little more bite from about 10-30 mph. With the hp of that machine it seems like it could do 70 with no problem. The sound is a little weird too. I'm used to the Kawasaki v-twin sound and the three cylinder is a diffrent sound. I think it should be a home run for Deere. I forgot to mention the new Diesel XUV will be coming with a belt enclosure!
/ Gator XUV, 2009 vs 2010 #43
Will the belt enclosure be adaptable to the 2009 XUV 850D?
/ Gator XUV, 2009 vs 2010 #44
The supension is upgraded too, correct? How is it?? More travel?? More payload cap.?
/ Gator XUV, 2009 vs 2010 #45
I have seen the brochure for the new gator.
- bigger tires
- more suspention, inch or 2
- adjustable coils front and back
- diesel HAS ENCLOSED BELT
- same diesel motor and power,25 hp, but 35mph
- 825i 52hp, 44mph
all I can recall now.
/ Gator XUV, 2009 vs 2010 #46
flenth, The answer is no. They redesigned the motor and trans to be linked together and they inturn are isolated as a unit.
ORCM,
The suspension is upgraded and it does ride very nice in stock form. They will have a fox racing shock option available which is SWEEEEET. No more payload capacity but the new box does have more volume.
/ Gator XUV, 2009 vs 2010 #47
- bigger tires
- 825i 52hp, 44mph
Interesting. This suggests the 08 and 09 diesel XUVs can be tweaked for more speed. Not that I need it. I very rarely go full speed as it is.
/ Gator XUV, 2009 vs 2010 #48
Still looking at a release date in the spring?
/ Gator XUV, 2009 vs 2010 #49
ORCM,
Any analog dash gages at all? :)
/ Gator XUV, 2009 vs 2010 #50
I posed the question to my dealer that a wider belt would only give you a couple a three miles per hour more but the engine top speed seems to be based on miles per hour and not rpm's.
He just looked at me and smiled. :D
John Deere 995 (A60462)
John Deere 995...
2008 FORD F-150 (A60736)
2008 FORD F-150...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
