yanmar 1900 clutch
/ yanmar 1900 clutch #1
joeshort
The turnbuckle came loose from the clutch. I put the turnbuckle back on the clutch and now the clutch works totally backwards. I tried to turn the clutch arm around and now it won't engage at all. Is there a simple solution or do I have to split the tractor to fix it? Any help would be appreciated.
Joe Short
/ yanmar 1900 clutch #2
Joe Short
What do you mean by "works totally backwards"? Sounds like you need to study up on how a clutch works.
Yanmar Tractor Parts: CLUTCH
What I mean is that in order for me to run my tractor, instead of pushing the clutch to engage the gears and releasing it, now I have to shift into gear and push and hold the clutch in to engage the gears and move the tractor. If I let up on the clutch, it will disengage (just as when you pushed the clutch in in normal operation it would disengage).
/ yanmar 1900 clutch #4
Hey, that actually could be handy in some situations... it's like a gas pedal - you just need to link your throttle cable into it now! :D
in all seriousness - thats not too good. I'm not sure about the transmissions in tractors (used to motorcycles) but is seems like the clutch fingers are installed backwards - that would cause it to engange when it should disengage.
/ yanmar 1900 clutch #5
I can't imagine how that could happen, even with something destroyed/ubhooked inside. The pressure plate applies pressure in it's relaxed state and releases with pressure from the TO bearing on the fingers. From the picture, what # is the arm that you installed backwards?
/ yanmar 1900 clutch #7
Turnbuckle is #23 and the other stuff on that rod?
You are saying only that part #23 came out of part #18? And then you put #23 back into #18? Nothing more?
So now #18 points up instead of down?
I'm confused.
/ yanmar 1900 clutch #8
Sure would like to see a pick of the linkage setup. And then go from there.Have a good idea whats wrong something tells me it's internal but I am far from an expert.
Carey
/ yanmar 1900 clutch #9
If arm # 18 will go upside down, it's going to require a split. Either the pin is sheared or clutch fork 17 has somehow become disengaged from clutch release, (throwout), bearing #15, and you will never get it back in without a split, and probably parts replacement.
/ yanmar 1900 clutch #10
I made a pic of my 1700. It should be similar. If you will pm me your email address I will send it to you
/ yanmar 1900 clutch #11
Norm posted the link to Hoye's diagram.
It still points in the same direction as before. Never seen anything like it. It doesn't make any sense to me. Apparently I will have to split the tractor in two as it doesn't make any sense to me.
That is what I am thinking too.
I was actually able to take the steering box off and reach inside, pull the throw out bearing up the shaft and reconnect to arm, put spring back on, readjusted clutch and now works properly.
/ yanmar 1900 clutch #15
I had a good guess on that one. Internal Linkage moving back_ _ _wards. good to hear it was a easy fix. Still wondering what caused it.
/ yanmar 1900 clutch #16
Good to know. Did not realize it was accessable through there.
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2016 CASE CX37C EXCAVATOR (A65053)
2016 CASE CX37C...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
