yanmar 1900 clutch
   / yanmar 1900 clutch #1
joeshort
The turnbuckle came loose from the clutch. I put the turnbuckle back on the clutch and now the clutch works totally backwards. I tried to turn the clutch arm around and now it won't engage at all. Is there a simple solution or do I have to split the tractor to fix it? Any help would be appreciated.
Joe Short
   / yanmar 1900 clutch #2
Joe Short
What do you mean by "works totally backwards"? Sounds like you need to study up on how a clutch works.
Yanmar Tractor Parts: CLUTCH
What I mean is that in order for me to run my tractor, instead of pushing the clutch to engage the gears and releasing it, now I have to shift into gear and push and hold the clutch in to engage the gears and move the tractor. If I let up on the clutch, it will disengage (just as when you pushed the clutch in in normal operation it would disengage).
   / yanmar 1900 clutch #4
Hey, that actually could be handy in some situations... it's like a gas pedal - you just need to link your throttle cable into it now! :D
in all seriousness - thats not too good. I'm not sure about the transmissions in tractors (used to motorcycles) but is seems like the clutch fingers are installed backwards - that would cause it to engange when it should disengage.
   / yanmar 1900 clutch #5
I can't imagine how that could happen, even with something destroyed/ubhooked inside. The pressure plate applies pressure in it's relaxed state and releases with pressure from the TO bearing on the fingers. From the picture, what # is the arm that you installed backwards?
   / yanmar 1900 clutch #7
Turnbuckle is #23 and the other stuff on that rod?
You are saying only that part #23 came out of part #18? And then you put #23 back into #18? Nothing more?
So now #18 points up instead of down?
I'm confused.
   / yanmar 1900 clutch #8
Sure would like to see a pick of the linkage setup. And then go from there.Have a good idea whats wrong something tells me it's internal but I am far from an expert.
Carey
   / yanmar 1900 clutch #9
If arm # 18 will go upside down, it's going to require a split. Either the pin is sheared or clutch fork 17 has somehow become disengaged from clutch release, (throwout), bearing #15, and you will never get it back in without a split, and probably parts replacement.
   / yanmar 1900 clutch #10
I made a pic of my 1700. It should be similar. If you will pm me your email address I will send it to you
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A54607)
2016 INTERNATIONAL...
