Anyone seen this?
/ Anyone seen this? #1
mrtfelton
Member
Dallas, NC
JD 3032e
All four wheels spin in mud on my 3032e beast with out depressing the diff. pedal. Do I have a problem or is this normal? I checked the adjustment linkage on the Diff. lock valve. I did notice paint on the valve that made me think the valve might be sticking on the seal. Thanks for your help in advance!
/ Anyone seen this? #2
Not my speciality, but I doubt the the dif is locked as that would be hard not to notice when on hard surfaces. maybe some kind of limited slip in the newer machines?
Does it happen under a load or just running light? If it happened under a heavy load I might be more concerned.
JB.
/ Anyone seen this? #3
With light loading and poor traction I can spin all 4 wheels on my 4x4 Kubota. Not using diff lock I typically spin one front and one rear. With diff lock and poor traction I have 3 wheel drive.
Pat
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Massey Ferguson 10 Square Baler (A65640)
Massey Ferguson 10...
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
John Deere Tractor Fenders (A65640)
John Deere Tractor...
Skeleton Backing Plate (A62679)
Skeleton Backing...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
