Quick Hitches Quick Hitch
/ Quick Hitch #1
Big Bri
Kubota MX5100
so i've read a few threads about quicks and saw one in action on a smaller JD. my question is
with my tractor having a cat 2 3ph do i need to get the cat 2 quick hitch. and if i get the cat 2 quick hitch will it work on my cat 1 implements.
i have some implements that are cat 1 and some that are cat 2.
thanks for the help
Brian
/ Quick Hitch #2
Look into getting the 2, and add the bushings on your cat 1 attachments (implements).
/ Quick Hitch
thats what i wanted to know, thanks guys
/ Quick Hitch #5
Hmm, I still think the spacing will be different.......
/ Quick Hitch #6
Me too. Standardized pin spacing on implements is:
Cat 0 - 20"
Cat 1 - 26"
Cat 2 - 32"
Cat 3 - 38"
Cat 4 - 46"
So it stands to reason a Cat 1 QH would be wide enough to pick up lift pins that are 26" apart. It should follow then, that a Cat 2 QH should be wide enough to pick up pins that are 32" apart. I think the actual QH inside widths are 27" and 33" respectively. And I think there's one designated a Cat 1/2 that is Cat 1 width with Cat 2 hooks.
//greg//
/ Quick Hitch #7
Pat's quick hitch isn't width dependent. Just put the bushings on the cat one stuff. I do believe Pat's has a cat 2 set.
1998 Ford L9501 Louisville 101 Truck, VIN # 1FTYN90K4WVA35579 (A61165)
1998 Ford L9501...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2000 JOHN DEERE 310E BACKHOE (A62129)
2000 JOHN DEERE...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
