PTO Backhoe Conversion? Please Help!
/ PTO Backhoe Conversion? Please Help! #1
waggy5
Member
New York
Kubota M7040 & B2320
Hi, I would like to convert a 3 pt backhoe that operates off a PTO pump to operate off my tractor remotes. Any suggestions? Thanks........
/ PTO Backhoe Conversion? Please Help! #2
How many GPM does you BH require? Does your tractor produce that GPM. Do you have remotes installed now?
/ PTO Backhoe Conversion? Please Help! #3
I just answered your other post, Please do not double-post your question-it makes it very hard to help you when answers to questions are scattered between different forums.
My tractor has 16.1 gpm flow rate and has two (2) sets of remotes. I do not know the flow rate of the BH. The BH was once mounted to a large flat-bed truck. It weights about 1 ton. 12.5' reach.
/ PTO Backhoe Conversion? Please Help! #5
The 16 GPM is plenty, in fact your hoe will be faster than you may want. If so, just reduce rpm.
Hi, I am fairly new to posting and the correct "ways" to post questions; but anyways, I am trying to figure out if I have to do any type of work to the existing valve system on the backhoe that goes to the operating levers. I have hooked into one set of remotes and "opened" my hydraulics to allow fluid to flow into the BH valve. When I do this the system will not allow fluid back to the tractor and dead-ends. After blowing one of the lines I new something was not quite right, so before I go any further I was looking for help and new by browsing the vast knowledge here on the net I would get some great advice. Thanks. When I hook up my Split-Fire woodsplitter in the same maner the fluid flows back and forth properly. By the way, the Split-Fire is one heck of a machine! I modified mine by adding 4" to the top and replacing the far end with a heavier end with "wings" to aid in the spliting function. I am able to split up to 4 cords per hour with the help of two other people.
/ PTO Backhoe Conversion? Please Help! #7
When you say, open the hydraulics, what did you mean? Did you bungee the lever open?
I believe the return from the BH should go to reservoir.
Check your QD's also.
/ PTO Backhoe Conversion? Please Help! #8
Are you trying to put a closed center BH on a open center tractor?
1) I use a bungee-cord to hold the lever open which allows the hyrdaulic fluid to flow to the BH, wood splitter, etc...
2) The tractor has open center hydraulics,
3) I am reseraching the net to try and find info on the BH. I will post as soon as I can find out anything.
4) I was looking at feeding the BH with one remote and planning on running the return line from this remote directly into the tractor housing/sump?
Does this sound correct?
/ PTO Backhoe Conversion? Please Help! #10
I'm willing to speculate as much as the next guy.
If you bungee a remote open for a splitter, it should work the same for your backhoe. Just plug the return from the backhoe into the other quick connect just like you did with your splitter.
/ PTO Backhoe Conversion? Please Help! #11
What line did you blow ?
was it one of the functions dipper-stabilizer-swing if so you might have a valve that is not in the neutral position.
Try using air to test the system instead of using your tractor hyd. before you damage it, I would test it while it's mounted on the tractor be careful air can still have enough pressure to move a function and put the return line in a bucket to catch any hyd fluid that will be in the system.
If it's a closed system air will not go through the valves when they are all in the neutral position and will flow through in an open system.
/ PTO Backhoe Conversion? Please Help! #12
waggy5,
What exactly were you doing when the hose blew.
You never did say if you had QD's on the BH lines. I am thinking that the valve should have gone into relief. Just what pressure do you have on your pump. Do you have a hydraulic gage.
I put a QD on the infeed and the return and plugged them into appropiate tractor remotes (i.e. same set of remotes). With the tractor idling I then bungeed the remote lever down/open. Every hydraulic line on the backhoe acted as if it had pressure. The first line to blow went to the dipper. As soon as this happened I un-bungeed the remote. I replaced the blown hose with a new one. I tried it again, no broken hoses, but each and everyone hose acted as if it had pressure to it. There are no gauges on the BH. I am trying to determine what type of BH it is. No luck yet. I do know that it is at least 20 years old.
Of note: The BH does work if you hook up the pto pump. It just does not have much ripping/pulling power even at 540 pto speed. Also, the hydraulic oil gets extremely hot when feeding off the reserve tank and, finally, it is very difficult to hook up the pto pump to the tractor. For these reasons I am trying to figure out how to convert to remotes. I am going to put a QD back on the infeed and then just run the return into my tractor sump this week and will report back my findings.
Hi, I found out that the Backhoe is a Davis Model 185. Any guidance would be greatly appreciated!
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
New Holland 451 Sickle Bar Mower (A66408)
New Holland 451...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
