another snow plow adapter thread - b7800 & weston
   / another snow plow adapter thread - b7800 & weston #1
z0lt3c
Hunterdon Cnty, NJ
2020 Kubota BX2380
another snow plow adapter thread - b7800 & western
I found a pretty decent looking 7' Western plow locally and I am thinking about adapting it to run on my tractor. I know there are a bunch of threads on here on this topic already, just looking for some specific advise.
I would like to mount the plow onto my FEL, which has an ATI skid steer q/A adapter. I also have a set of carry-all forks i use on the FEL with holes drilled into the forks for bolts. So I have a few options. 1) attach a skid steer q/a plate to the plow frame. 2) attach the plow frame to forks in a removable manner.
I've seen alot of people try and shorten the plow frame, I assume that I would want to try and do the same... Which may result in #1 being easier then #2? #2 would be cheaper and i think i will just need some L brackets and bolts where-as #1 very well may require some welding.
Here is a link to the pic of the carry-all; Picture Link
I should mention that the plow will just be used for my personal driveway, which is about 1000 feet long, level and gravel/dirt/crusher run. Here in NJ, we don't get a ton of snow, but I'm sick of using my buckets and having to empty them when they fill up.
Thanks,
   / another snow plow adapter thread - b7800 & weston #2
I shorten mine for my BX due to the size of plow (big) and size of tractor (smallish). The B would be ok for not making mount shorter, but shorter is better for manuvering better. I would say mounting a frame to a QA is better. You never know if you need to swap front implements and when season changes- its easier. I thought the plow is a meyers, mine looked just like yours, I could be wrong though. When I got mine, it was painted over several times and rusted big time.
Thanks for the feedback. It could be a meyers... The PO claimed it was a "weston" but I dont see any identification on it. I'm going back to pick it up tomorrow so I'll take another look at it.
Picked it up today. It's a WESTERN plow, 7 feet, and all the mechanicals appear to be in order. The guy even threw in the pump which was used on the pickup truck it came from. I got everything for $125 (plus another $20 trailer rental) which seems like a pretty good deal to me. I don't think I will need the pump, I will use the tractor hydro.
I didn't realize how big this thing was until I saw it in person. It's huge, this is the professional series not the smaller standard series. I hope it's not too big for the B7800, i can see now why cutting down the frame and keeping the weight closer to the pins would make it easier to manage. Now I just need to figure out a way to mount it.
   / another snow plow adapter thread - b7800 & weston #5
I didn't realize how big this thing was until I saw it in person. It's huge. I hope it's not too big for the B7800, i can see now why cutting down the frame and keeping the weight closer to the pins would make it easier to manage. Now I just need to figure out a way to mount it.
Z0lt3c
7 feet may be a little big for your B7800, but you can always cut it down. It's well worth the money you spent.
Harvey
How it is pump powered in the original application? I assume the hydro lines connect to the right and left cylinders, but what about the big front bracket. Was this lift control? I guess I am missing the controller?
   / another snow plow adapter thread - b7800 & weston #7
Just completed my plow conversion the other week. Really proud of it as it was some time in the thinking department. While I was thinking my farmer freind did the welding and did the job. Standard 3pt config. put some rubber top and bottom to make it easier on the fancy driveways. Just got the chains in the other day to give her some bling:D
   / another snow plow adapter thread - b7800 & weston #8
Can anybody explain to me exactly what the pump does and how it is powered in the original application?
It should be hooked up to the battery with heavy cable.
I am going off memory since I saw the pics last night but now they are gone.
You are correct about the hydro lines, The front bracket is what would have lifted the chain that attaches to the "A-frame" therefore lifting the plow.
There wasn't any controller shown in your pics IIRC.
Thanks! Would it possible to wire up this pump to the battery of my tractor?
   / another snow plow adapter thread - b7800 & weston #10
Yes, but why when you already have hydraulics available?
Plus you have to buy a controller.
1611 (A57192)
1611 (A57192)
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
