Add lights to roll bar?
/ Add lights to roll bar? #1
ScottAW
Member
Anyone have any tips or tricks for adding the lights to the roll bar of a GC2610? Wondering if there are any good points to pull power from. Any suggestions on lights to look at?
/ Add lights to roll bar? #2
Do a search of old posts and you'll come up with more solutions than you can handle.
A quick one that comes to mind is two clamp/bolts ( the type they sell to mount a spare tire to a trailer). A piece of 3/16" to 1/4" aluminum (easy to work and doesn't rust".
/ Add lights to roll bar? #3
On the GC2600 there is a 4mm power receptacle at the back of the tractor to the left of the upper stabilizer link coming from the wire loom so suspect the 2610 will have one there as well. An audio speaker banana plug fits the plug nicely. The wire is 18 gauge so should easily handle a 15 amp draw.
Thanks all! Just ordered some Hella lights from Amazon for $9 each, will wire them up and see how it works out.
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
