Add lights to roll bar?
   / Add lights to roll bar? #1
ScottAW
Anyone have any tips or tricks for adding the lights to the roll bar of a GC2610? Wondering if there are any good points to pull power from. Any suggestions on lights to look at?
   / Add lights to roll bar? #2
Do a search of old posts and you'll come up with more solutions than you can handle.
A quick one that comes to mind is two clamp/bolts ( the type they sell to mount a spare tire to a trailer). A piece of 3/16" to 1/4" aluminum (easy to work and doesn't rust".
   / Add lights to roll bar? #3
On the GC2600 there is a 4mm power receptacle at the back of the tractor to the left of the upper stabilizer link coming from the wire loom so suspect the 2610 will have one there as well. An audio speaker banana plug fits the plug nicely. The wire is 18 gauge so should easily handle a 15 amp draw.
Thanks all! Just ordered some Hella lights from Amazon for $9 each, will wire them up and see how it works out.
Misc Machine Tools (A50860)
Misc Machine Tools...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2021 Wacker Neuson BPU4045A Reversible Vibratory Plate Compactor (A49346)
2021 Wacker Neuson...
2013 Nissan Altima Sedan (A48082)
2013 Nissan Altima...
