kubota L2800 cab plans
/ kubota L2800 cab plans #11
its a 1/4 inch thick so im gonna try it and brase it really well
I do not have any experience with roll cage design. But in my experience with supporting loads vertically or horizontally the width of the material is much more important than the thickness. For example I believe it would be more difficult to bend 1/8" thick 2" square tubing than 1/4" thich 1" square tubing. This is certainly true for I beams and Angle with static loads.
Here is some info on SCCA roll cage requirements Roll Bar Basics | Advance Auto Parts
im not concerned about it rolling its just to support itself and the snow on top of it it is coming off in the summer when i use the tractor in the woods witch is when i am concerned about it rolling. its all gonna be one piece that i can back in the barn and unbolt and lift off. i might look into useing something bigger but right now i wanna try to stick with the steel i just bought that i cant take back
well i started at 6 PM and got this much done till now [3 AM] its coming pretty good i think. FYI im 15 years old and taught myself how to weld and i did that hole thing by my self at the same time im rather sick with a cold but im one of them country boys that it would take hand cuffs to keep me sitting down and doing nothing. :)
/ kubota L2800 cab plans #14
Nice job so far! Think I'm gonna go the same route , welding is the best skill I learned?
theres a better one of the welds..
heres what its looking like so far. any seggestions and comments are welcome
and yes i am cutting holes for windows in those. the hole front in the square of the tubeing is gonna be plexy glass a side window on each side and one on back a old heater core and fan from an old car is gonna heat it. and many many hours of sheat metal work to fill all the little gaps and holes. and a door with a spring to keep it closed with as best of a seal as i can get. the front and back are gonna have wipers with just a little round crank at the sealing of the cab to turn them. i have lights to go on top. its gonna be insalated in the gap of the steel tubeing is gonna be full of insalation and then some 1/2 inch ply wood on the inside. so far i have about 20 hours and $300 into it but thats for everything other then the glexy glass and thats for all the cutting blades welding wire and grinder wheels to make it and the ply wood steel and bolts. im going all out to try to do the best i can cause im trying to get a little fab work business going and i want something to show to prove my work.
Mayrath PT 10" x 62' Grain Auger (A60462)
Mayrath PT 10" x...
Mini Excavator Grapple (A60463)
Mini Excavator...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2020 PETERBILT PB337 SERVICE TRUCK (A59823)
2020 PETERBILT...
2009 International Pro Star (A60462)
2009 International...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
