homebuilt backhoe
/ homebuilt backhoe #41
Here is the chain swing mechanism on my backhoe. 2 chains pulled by SA cylinders. The ends of the chains are pinned and they ride on smooth "wheels" instead of sprockets. It should be possible to get at least 270 deg. from this type of mechanism.
Might need to do a side dumper to not interfere with the rear mounted hoe.
Okay WB - I'll stop hijacking now. ;)
That's a little different that I had in mind, but that's an interesting setup.
I was thinking of a single sprocket with a chain wrapped around it. Theoretically, with the single sprocket setup you could build a backhoe with a full 360 degree swing or even more.
/ homebuilt backhoe
I still dont see how your going to get any depth with it maybe I am just thick in the photo your boom cylinder apears to be at least two thirds extended the pin point seems a long way away from pivot. I am eager to hear you explain ......:confused:
here i will try to explain
first off the boom cylinder has 18'' of travel. so i sould get aboat 5 1/2-6" of digging depth.
but i will probaly move the cylinder so i get more depth. but i will try it as is first
/ homebuilt backhoe
heres some pics i found:D
/ homebuilt backhoe #44
Is it going to be called as the sign on the wall says 'scoopmobile"?Thanks for the pics its really coming together, it was great to scroll through them and see it proceed.keep em coming
/ homebuilt backhoe #45
I like what you've done with the bucket linkage. That curved shape looks good, but also looks like it will give you more functionality.
/ homebuilt backhoe #46
I commend you on your efforts, but.
I believe the geometry on the bucket is not correct. I also believe you will put cracks in that bucket at the edges of the 4 x 4 angle. There should be a 2 or 3 in bar under the top of the bucket from side to side, below that angle iron to support all the force you will place on the bucket. As you push up and down on the tip of the bucket, it will start to bend and eventually crack.
In the picture with the dipper stick vertical, and the bucket on the tip, is where I see potential for breaking. If you push on the cylinder , the angle of the bucket to the roll over tabs is wrong, in my opinion.
/ homebuilt backhoe
Yes i know the bucket shape is not correct. the sheet i was cutting the sides out on was not wide anof.
The bucket does have a chunk of angle iron under the ears.
Ya i know its not done yet. will be getting a shorter cylinder for it also.
/ homebuilt backhoe #49
Just wanted to say you have done a great job so far, keep the pictures coming. By the the way you need to take that bucket to the dentist and have a set of dentures made for it. Although with the smooth lip style bucket they make great grave holes. But having teeth I think you will enjoy a lot more. be good.
/ homebuilt backhoe #50
After you finish that, why dont you make a backhoe for my Yanmar.:D Could have some fun. Great job on your backhoe.:)
/ homebuilt backhoe #51
Love the updates and keep them coming. Great project!!!
/ homebuilt backhoe
Thanks:eek:
sorry but i think this my last backhoe build for a while
/ homebuilt backhoe
Thanks:eek:
Ya i was planing on making a tooth bar that way i can have a smooth cutting lip and teeth for hard digging
/ homebuilt backhoe #55
in my opinion since this thing is going to be difficult to position if I were you I would make a seriies of holes for the cylinder to mount in to make it more versatile, keep plugging more productive than me when I was a kid, she will probaly crack all over the place but , thats the cool thing about welding you learn and improve all the time.
/ homebuilt backhoe #58
Are you planning on adding weight to the trailer? I worry that you will just drag yourself around? Just a thought, You are doing a nice job on it!
MASSEY FERGUSON 240 TRACTOR (A64278)
MASSEY FERGUSON...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A67148)
2025 DELCO T/A...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
More info coming soon. (A64557)
More info coming...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A67148)
2012 FORD E-350...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
