Meyer Plow for my tractor
/ Meyer Plow for my tractor #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
Ok, its been beat to death but here is my setup.
I started off with a old Meyer ST-78 plow I got of CL for $80. The cylinders were rusted and the plow face was rusted through in 2 spots. It was solid other than that, not bent, and had a brand new cutting edge included. Every nut and bolt fought me and many had to be cut off with a cutting wheel or sawz-all.
Here are a few pictures.
After cutting all the bolts and removing the plow face it was off to the sandblasters. I also made a shopping list and hit the internet, TSC, and my local hardware store.
I spent $100 on the sandblasting and another $30 on bolts and paint.
I also got new plow shoes ordered, plow markers, and trip pins for $80.
I then had to order the steel for the mount and new face. I had them make the face out of 11ga steel and they put the roll in it per my templet I supplied. For the FEL to plow adapter I use 1/4" stock and did the additions of putting on a 2" hitch receiver tube and tubes to accept another set of plow shoes if I feel they are needed later on. I have $140 in all the steel.
At this point I am into it about 10 hours of labor and $430
Chris
At this point everything has came back from the sandblasters and I had welded up a few cracks, welded on the new plow face, and welded up the plow to FEL mount. I then primed everything and put the plow in yellow and the rest in black.
I also ordered custom hydro lines to go from the remotes on my tractor to handle the left right movement of the plow and the new cylinders and a Meyer Decal Kit. I have about $220 in this which brings the grand total to just about $650 and about 20 hours. More than I envisioned at first but much cheaper than the $2000 to $2500 I was quoted for a plow new.
Chris
Later today I will assemble the cutting edge, A-frame, and odds and ends. I am still waiting on the cylinders, hydraulic hose, along with the plow shoes. I will update this as parts come in and post some pics once I get it on the tractor and working.
Chris
/ Meyer Plow for my tractor #5
All the work and running around is really worth it - look at the money saved..way to go, the plow is looking like a brand new one. I really enjoy it when I come across deals on things folks have written off and I am able to bring them back to life..great job.
/ Meyer Plow for my tractor #6
great job so far I really enjoy these threads. Seeing a plan come together, eager to see it mounted.
/ Meyer Plow for my tractor #7
Nice..very nice job done!!!..now thats how you make money. :)
Shall be looking for action pics. when the snow starts to pile up. :)
Well I just got done putting it together. I am still waiting on the hoses, cylinders, and shoes but its all done other than that. I will mount it up next week but I first have a job moving gravel and leveling off a area for a neighbor.
Chris
Be careful Chris, its not a dozer blade-just a snow plow.
I do not plan on using this blade for nothing but snow. That is why I am waiting to mount it up. I will use the FEL Bucket and my 7' Woods Grader Blade for the gravel project.
Chris
/ Meyer Plow for my tractor #12
Chris
Got it! I mis-read you post...I read it like you where going to use the plow for that job!
/ Meyer Plow for my tractor #13
Chris,
Are you going to mount that blade to the bucket or directly to the loader arms? My 6.5' Meyer project is nearly done and it will mount to the Koyker loader arms.
The Meyer original A-Frame is made of tubing and one angle iron. We cut off the chain, hose loops, and the two quick mount lugs, leaving only the bare A-Frame. The moldboard and trip frame are temporarily disconnected. We are boxing in the upper and lower part of the A-frame and making the box as close as possible to the moldboard in order to bring minimize the distance from the loader arms to moldboard.
Each end of the box has two welded vertical brackets that will pick up the four pin holes/pins previously occupied by the bucket. Can send you photos.
The angling valving, with help from Rob, is done along with another valve to the new rear remotes for the log splitter.
Steve I am made a mount to take place of the bucket. I did not want to modify the plow because I may put it on a truck someday. The mount I made can be seen in the pictures. The mount will go on in place of the bucket then the plow will attach to it. I will post pictures in 2-3 days after I am done using the FEL for some gravel work.
Chris
/ Meyer Plow for my tractor #15
For what it's worth I added pin holes to my fork lift attachment. I remove the forks and mount a plow just like yours to the fork quick attach.
Dan
Great idea Dan. I have forks but they are the clamp on style so I had to make a adapter but I love the way you used what you had.
As for a update on my project today I went to Harbor Freight and bought 3 casters and made a dolly for the plow. Its getting painted now and will post pics latter but it allows me to move the plow with 1 hand and push it to the corner of my barn out of the way.
Chris
Well, its been a few days. Been waiting on parts so on Sunday I built a dolly for the plow. I got the wheels at HF for $2.49 each so it was a cheap project using some steel I had laying around. The main body is built from some track from a electrical project I had done, the main piece is 42" and the T-ed piece is 36" long. The cross braces are made of some 12" pieces of small angle iron. I made the rest out of a piece of 5/8" rod that was 6" long, a few odd pieces of angle iron, and a strip of plywood. I put a piece of rubber on the back to keep the plow from slipping.
Chris
I got the hydraulic hoses and cylinders last night so I mounted up the plow for the first time. I also go the shoes on Tuesday. It worked great. I am just now waiting on the decal kit which may be here today.
Chris
/ Meyer Plow for my tractor #19
Nice..very nice,shall be looking forward to actions pics. :)
Oh yea. I also forgot, I am getting some conveyor material to put back on a Snow Deflector. My friend has tons of it laying around his work. He is getting me a piece but I have not seen him since Sunday to get it. I will post more pics.
Chris
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
2012 WESTERN STAR  4900SA  SLEEPER (A65643)
2012 WESTERN STAR...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
