need help with my 165
/ need help with my 165 #1
savitz hill farm
northeast PA
massey 165,farmall super h,john deere LA,
I'm new to the forum and need help with my 165 massey.I have a bad trans leak from the rear weep hole.I have changed all the seals the main shaft and still it leaks.1500 dollars and still the same problem.:confuse:yes it is a multi-power,other than this it has been a great tractor for many years,best i ever owned. thanks harry
/ need help with my 165 #2
You may want to take this thread to the Massy Ferguson forum up the page a bit. Better chance of getting a response:)
Mark
/ need help with my 165 #3
Welcome to TBN savitz hill farm! :)
I relocated your post to the Massey forums as another member suggested. You will most likely get a better response here. I left a re-direct to this post in the original forum so you can find this post. ;)
/ need help with my 165 #4
being a multi power I can tell you right now that its a expensive thing to fix.If you look inside the place where the shaft from the clutch goes through into the trans its a housing.Anyway inside there's a couple of metal rings they actually look like like piston rings with a hook on them to keep themfrom spreading open to far.what usually happens is that if there worn they can't open up any further so oil seeps by.The down side to this is that it can also be the housing itself thats worn so it gets very expensive very fast especially if the housing needs to be replaced.On mine I ended putting in new rings but I also took some time and filed out the ring stops to allow the rings to open up a bit further.You can't take to much off either or you won't beable to put things back together as the rings need that to keep them from spreading to far as everytrhing is done what you might say like working inside a hole so if you don't have a manual you should have one for this procedure good luck as always Larry
John Deere 410D Backhoe (A62679)
John Deere 410D...
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
2021 John Deere 4044M (A64126)
2021 John Deere...
First Choice GM30-72 Finish Mower (A66408)
First Choice...
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
