I see where some of the companies that specialize in pole barns are going to laminating boards together for their posts. In the few cases where I've seen this, they are attached to a concrete slab. From what I understand, 2x material is not rated for ground contact. It has less chemicals in it then the 4x and larger wood. If you are setting posts in the ground, with or without concrete, I would use wood that is rated for this application.
With youe posts on 8ft centers, be sure to use 2x6's for your purlins. I'd also make sure they were 16ft long and overloap the ends. If you are using metal siding, then every 6 ft would work, but if you are using OSB or plywood for your siding, you need to be have at least 4 ft centers on your purlins, and less if you are installling Hardi Lap Siding over the sheething. If you are thinking of a rock vineer, then 2 ft centers and 3/4 plywood is required.
While I can't speak for areas that get snow, here in the South, 7/16 OSB for roof sheething on 2ft rafters is code and very common. I've seen roofs where you can see the rafters through the shingles, but think that is from other causes. In one case, I saw this on a roof that was shingled when the decking was wet from a rain, and 15 pound paper was used with 3 tab shingles on top. In my opinion, they did everything wrong, and as a result, the roof looks like it. 3/4 plywood on a roof is allot of weight, but it's also allot of money that won't accomplish anything. For those that want to upgrade from OSB, 1/2 inch plywood is just twice as much money as OSB. 3/4 plywood would be about 3 times as much money as OSB. Whatever you use, don't forget the H clips.
Do you know how to build trusses? or will you buy them? From what you've written, it sounds like you are planning on building them. There are some websites that show how to build them. I'd do a search for this and copy the desing for your span and eve design.
While pole barns are very simple to build, what you use is based on what your eventual plan for the building is. If you are thinking of making it into a house one day, then it's important to plan for that now.
Good luck,
Eddie
