Power Beyond
/ Power Beyond #1
cmh61271
Deere 4310 eHydro
I have power beyond ports. Can I use these ports to plug into a bank (2) hydraulic valves? I would like to use one for my top link and one possibly for a grapple. Can someone give me a link of the valve I need? I assume I need a valve that if neither valve is selected it flows back to the tractor.
/ Power Beyond #2
Yes, you can plumb a valve into the PB lines...But I need to know what the rated GPM of your machine is before I can suggest a good match for you.
/ Power Beyond
it is a 4310 deere with ehydro and 420 loader
Thanks
/ Power Beyond #4
Kennyd, I am looking for the same thing but for a Kubota BX24. Where would I look for a valve for a grapple. Remotes are going to be installed soon.
Thanks
Jim
/ Power Beyond #5
CMH,
You know that you can add a factory remote to your machine right? Actually, you already have the valve(it's mated with the loader valve) but no way to control it. The JD kit sells for about $250 and includes everything you need...it's a nice clean setup.
/ Power Beyond #6
Thanks
Jim
Confused:confused:
Your getting remotes installed soon? Or do you mean you are adding remotes soon and need a valve suggestion?
I am not sure the best way to do it on a BX24-there are LOTS of options. Do you want a manual valve, or a electrically operated valve?
/ Power Beyond #7
I am having remotes put in so that I may use a grapple. I assume that I will need some sort of valve to control the opening and closing of the grapple itself. I may be wrong this is new to me
/ Power Beyond #8
By definition, "remotes" include a valve to control them...The only extra's you will need is hose and QD's (quick disconnects)
/ Power Beyond
CMH,
How difficult is it to install?
/ Power Beyond #11
Will take about 4 hours or so, mostly it's just getting to everything due to the limited space is the problem. Removal of the right rear wheel is necessary, as well as cutting the slot in the right fender.
Below is a picture of what you get in the kit...LVB25569 is the part number for the newer unit's (need serial number to verify which kit you will need)
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
12ft. 28 Gauge R Panels (A65640)
12ft. 28 Gauge R...
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
3 Point Hitch Root Rake (A65579)
3 Point Hitch Root...
1987 Chevrolet Pickup Truck, VIN # 1GCEV14H1HF371433 (A65563)
1987 Chevrolet...
