Worklight wiring questions for you Electrical Gurus
/ Worklight wiring questions for you Electrical Gurus #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
OK, I'm lining up everything for my ROPS worklight wiring project. I'm installing 2 front and 2 rear for a total of 4 - 55w each worklights.
I've picked up 2 factory Kubota pushbutton switches (one for the 2 front lights, one for the 2 rear lights). The switches are push-in (on) push & out (off), but come from another model tractor, so there are no pigtail harnesses on my tractor to match the pigtails on the switches. There are 5 wires in the switch pigtail - 3 wires for the pushbutton on/off control and 2 wires for the light bulb inside the switch.
My question is regarding the 3 wires tied into the pushbutton power control. I took the switch apart and found which wire is which - 1 wire is the power ON wire and is activated when I push the switch in. The 2nd wire in the middle appears to be the ground wire. The 3rd wire would appear to be the power OFF wire and is connected to the lead at the switch position in the off position.
1. Do I even need to connect this 3rd wire to anything? I would assume that the power ON wire goes to my key switched hot wire, ground wire to a ground point, and the 3rd wire could be left unconnected. Am I correct?
Next is the wire gauge. I am going to wire everything up using this wiring diagram: http://216.77.188.54/coDataImages/p/Groups/183/183657/folders/273951/2227786wiring.JPG
I will run 10ga wire from the battery to the 30amp inputs on each of the 2 relays. I will then run 14ga wire from the switched fuse panel to the new push button switches into Pin 86 on each relay.
2. Can I run 14 ga wire from Pin 87 on the relay to each light, or does it need to be 10ga wire? The short factory power wires on each light are only 14ga wires.
3. Does the relay allow the full 30 amps to run through Pin 87, or just whatever lesser amperage that the lights require?
4. Can I run 14ga wire from Pin 85 to the ground?
Thanks in advance for your answers.
/ Worklight wiring questions for you Electrical Gurus #2
I did a similar installation on my tractor and also used some Kubota switches but I used the switches to control the lights directly and just used one relay that turned on whenever the key was on. A diagram of my setup is attached. Your method is probably a bit better since the full light current does not run through the switches but requires a bit more wiring. The switches should handle the current with no problem though.
I don't know if you have the same switches a I do but to power the lights in the switches I wired them in series to only put half of the full voltage accross each light so they would not be so bright. This is then wired into the circuit that is actived when the headlights are on.
#1 You are correct the other wire will not connect to anything.
#2 & #4 14 ga wire is fine for this since it is ony being used to activate the relay and should draw less than an amp.
#3 Only the required load current will run through the relay contacts
Let me know if you need any more help.
Steve
Good, thanks for the feedback.
The switches may be from an L48. They are green square switches with a headlight symbol on them.
I'll definitely wire in series to make them a little dimmer - I think they're pretty bright otherwise.
Thanks again.
/ Worklight wiring questions for you Electrical Gurus #4
Here are a few photos of my installation. I used some 2 pin inline connectors at each light in case I ever need to remove/replace a light. With the switch lights wired in series they seem to match the brightness of the other dash lights and they will probably last forever. If one light burns out though both will go out (like the old christmas lights).
/ Worklight wiring questions for you Electrical Gurus #5
3. Does the relay allow the full 30 amps to run through Pin 87, or just whatever lesser amperage that the lights require?.
E=IR
Only drawn load flows..
soundguy
/ Worklight wiring questions for you Electrical Gurus #6
If your lights are 55 Watts each they will draw 4.58 Amps each. 14 gage wire can safely carry 80% of 15 amps or 12 amps of continuous load. In other words you can safely put 2 lights on one 14 Gage wire, or all four on 10 gage.
You would probably want to use stranded wire, for the vibrations, and fuse them for 15A for two or 30 amps for all four. and don't be fooled by the fact that there is a picture of a head lamp on the switch, it may be designed for a vehicle that automatically uses a relay and was never designed to carry the full light load.
Oh by the way nice looking installation!!!
Check out the diagram. I am putting a 30 amp fuse right behind the battery, and running 10 gauge wire from the fuse to each of 2 relays, then running 14 gauge wire off the 2 relays to the 2 sets of lights. The switches are being used to switch the relays only, so minimal power is running through them. I'm not putting any other fuses inline. As far as I know, I don't need any more fuses than the one before the relays.
/ Worklight wiring questions for you Electrical Gurus #8
Should work fine they way you described it. You could add additional fuses after the relay's to protect them if you wanted to, but they are pretty cheap at 4.99$ for a 12v 30a 'foglamp' relay.. so you are not out much if on'es contacts smoke.. which will not be likely since you are fusing at 30a anyway. so.. yeah.. pretty safe with the supply side fuse.. etc.
soundguy
Thanks for all the input, fellas.
I finished wiring everything up and everything worked perfectly, first try.
Switches look good, too. I may dim the bulbs inside the switches if I think they're too bright at night.
I'll probably head out tonight to check the aim of the worklights. I'm interested to see just how bright the factory headlamps plus another 110w front and 110w rear up on the ROPS are going to be. Should be plenty bright, though.
/ Worklight wiring questions for you Electrical Gurus #10
Bandit, that looks really professional! What do you light mounts look like?
Where did you get these Kubota switches and do you have part numbers. I would like to do the same thing on my M 6800. Also what is the source of relays that you used? Thanks!!
OK, here are some pics of my bolt-on brackets before they were wired.
The 2 light switches are from an L39, I think, and the part number is 36919-54222. I ordered them from my dealer - they were around $33 each.
Relays - I had a local auto parts store order them in - I brought in this wiring diagram I got from another TBN member so we could match up the relays - around $10 each.
http://216.77.188.54/coDataImages/p/...7786wiring.JPG
/ Worklight wiring questions for you Electrical Gurus #14
Bandit, I now have the same Kubota switches you have. Can you help me in wiring them? I know the pair of wires ( black and red) are for the ground and power to the bulb on the switch. How about the top three, yellow, orange and blue. I assume I use only two of these. One to the fuse box and the other to Pin 85 and to the red of the first pair I mentioned. Is this right? If so, which two connect to the fuse box and to pin 85? On my switch, the orange one is in the middle. Sorry to trouble you
/ Worklight wiring questions for you Electrical Gurus #15
Nice work on mounting the lights Bandit. I like how you put Caplugs in the ends of the tubing, and covers on the threads of your bolts to protect your head from cuts.
Are you going to put the wires in plastic loom? That would finish it off very nicely.
I used 14GA wire on my relays for the lights and 18GA for the switches controlling the relay coils.
Yes, the wires are plastic loomed and zip tied to the ROPS. Worked great last winter.
Harold,
I can't remember much of the wiring. I thought I took pics of the connections, but I can't find any, so I must not have done it. I know I had to do some testing with the meter to determine what needed to be connected to what. I would have to pull some of the dash apart to take a look at my wiring.
I remember pulling the switch apart to look at the internal connections on the 3 wires to determine which one was which. Once the switch was apart, it was pretty easy to determine which one was the ground (the switch was connected to that wire both in the on and off position). I remember the other 2 being a bit tricky, and can't remember if all 3 were connected or if only 2 were. Like I said, I'm going to have to pull it all apart to take a look at the connections to re-aquaint myself with what I did.
I did wire the small bulb inside the switch to a wire from the factory lights that only is powered when I turn on the factory lights. However, I powered the relays through a switched ignition wire, so I can turn on the ROPS lights without turning on the factory lights, but only when the key is on so that I don't run the risk of draining the battery.
I think some of that may be a bit off.
I ran a 10 gauge wire with a 30 amp inline fuse directly from the battery to the 2 relays' Pin 30, just like in the diagram on the first page of this thread.
Pin 85 is a ground wire - connect that to the tractor.
Pin 87 is a power wire to the lights
Pin 86 comes from the dash mounted switch, so that the relay is only able to pass the 30amp battery power through pin 87 when you activate your green Kubota switch.
/ Worklight wiring questions for you Electrical Gurus #18
Thanks! Don't go to the trouble of disassembling your dash for this! I can figure it out with the information you gave. I really appreciate your response.
/ Worklight wiring questions for you Electrical Gurus #19
I think from what I have read elsewhere, pins 85 and 86 are interchangeable, and it would work both ways. There is another diagram posted many places that show using 86 as a ground. That is the only difference I see between your wiring and what I propose. Again, thanks. I sent you a private e-mail you can disregard. I was not sure you would see this posting.
I am using LED lights by Truck-Lite instead of halogens. They pull very little amps (I think 1.2 each) I tried them out in my yard one night with a 12V source and they look good. I am placing two trapezoid spots on the front and two floods on the rear. I will wire them separately on two different relays.
/ Worklight wiring questions for you Electrical Gurus #20
Here is a diagram I drew for some others...might be of a help to you.
5ft. Wooden Native American Statue (A61569)
5ft. Wooden Native...
New/Unused Landhonor 20ft x 20ft Carport with Side Walls (A61166)
New/Unused...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
1995 HESSE CORPORATION BEVERAGE TRAILER (A60736)
1995 HESSE...
2019 Chevrolet Ambulance (A60352)
2019 Chevrolet...
