Tachometer problem on a Jinma 284
/ Tachometer problem on a Jinma 284 #1
jjkane
Quakertown, Pa
2007 Jinma 284
The tach on my 284 up and quit a while ago and I am finally getting around to fixing it. I checked the sending unit and it generates approximately 4.5 to 5 volts AC at idle and increases as RPM's are increased. The tach doesn't work at all. My question is what voltage should I expect to see from the sending unit at idle and at a higher RPM?
jjkane
/ Tachometer problem on a Jinma 284 #2
The sending unit isn't really generating a voltage. Well it is as it is a hall effect sensor(coil in core) that reacts to the ring gear teeth passing in close proximity to the sensor. The signal that the tach gauge is reacting to is the frequency change as the pulses become more frequent as the RPM increases. The fact that it is putting out a voltage indicates that the sensor is probably OK, and the gauge is failing to make use of it...
/ Tachometer problem on a Jinma 284 #3
These sensors are notoriously fickle. As Ron indicated, the tach works on frequency, not voltage, so it's difficult for someone without an oscilloscope to verify operation. The 5V is a good sign though.
The most common problem is that the sensor has moved a little and is too far away from the flywheel. The first step is to make sure that the sensor is close enough to the flywheel, it should be about 1mm. The way to do this is: (with the engine off!) loosen the locknut, screw the sensor in until it touches, and then back it out 3/4 of a turn and tighten the locknut.
The next thing to test is whether that 5V signal is getting all the way to the tach input on the dashboard. If it is, my understanding is that the entire instrument panel needs to be replaced, there is no repair for the tach.
/ Tachometer problem on a Jinma 284 #4
Has anyone tried the replacement tachs at Surplus Center? I called once and was told all they had were the heads and no senders/ transducer units? Why would they try to sell incomplete units? bjr
/ Tachometer problem on a Jinma 284 #6
JJ
When mine quit working I ajusted it according to the instructions above and it worked for while longer then quit -- new sensor is cheap and the most likely solution:rolleyes:
/ Tachometer problem on a Jinma 284 #7
JJ
I had exactly the same experience, $19.50 plus shipping for a new sensor. I'll also add the that the guys who sell Jinma parts tend to get them to you on the double, I think I had a new sensor in the tractor two days after I ordered it.
Thanks to all who have replied. If I get home early enough one day this week I'll investigate further the wiring to the instrument cluster. I also have a scope I can put on the sender leeds to check for the change in frequency as the PRM's are increased.
Thanks
jjk
Here is an update on the tach problem. I found I was able to disassemble the instrument cluster and seperate the other gagues from the cluster leaving just the hour meter and tach in one piece. There is a board that is most likely the problem. If anyone has any defective cluster panels maybe I can get what I need to get a working set from them. Any help would be appreciated.
Thanks
jjk
/ Tachometer problem on a Jinma 284 #10
Tommy
All the other gagues in the cluster work that includes the fuel and ampmeter but the center portion is a combination tach and hour meter. I've been able to take the cluster apart so the picture I am posting is just the tach.
jjk
Although the tachometer is not as critical as things like temperature and oil pressure gages are but it is a handy bit of information when running things like a backhoe. Since the tach is an integral part of the instrument cluster I am trying to consider other options to get it running. I believe earlier models of Jinma tractors had individual gages instead of the cluster. I'd like to replace the cluster with individual gages and wondered if anyone has any experience with this. The question is if the sending units on the engine are compatible with the older gages. Any information would be greatly appreciated.
thanks
jjkane
/ Tachometer problem on a Jinma 284 #13
I followed the below directions, and my hugely annoying intermittent tach now operates correctly. Thanks
Jeff
Thanks Jeff
I'll check it tomorrow if the weather holds out for me.
jjkane
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
John Deere Forks (A64126)
John Deere Forks...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
John Deere 8320R (A64126)
John Deere 8320R...
