homebuilt backhoe
/ homebuilt backhoe #1
welderboy14
Surrey, BC
John Deere 325
/ homebuilt backhoe #2
I am no expert, but I was instructed that having two 2 spool valves was not advisable, and to go with an assembled (in my case) 6 spool valve. J_J gave a great link Bailey Hydraulic Cylinders Manufacturer for hydraulic valves and such. my valve will come from them. as far as the pump I will be using a 4-5 GPM pump on a 9HP motor to work 4 2 inch by 10 inch stroke , and 2 1 1/2 inch x 10 1nch cylinders. I do hope I have been some help, and be patient as there are some really good and Knowledgeable people how subscribt in this form.
/ homebuilt backhoe #3
I know I've mentioned this in other threads, but this guy on youtube has the most detailed and comprehensive advice on building a towable backhoe. He's real careful to not give out any dimensions or measurements that would be copyrighted in a purchased plan, but as for technique and methodology, he's very thorough. I can't say much more than he has already said.
Buy the plans if you are new to hydraulics (if you haven't already). There are half a dozen or so out there when you search for "Towable Backhoe". Someone else will have to give opinions as to which plans are better than others.
As for pump size vs. cylinder size, etc. it's kind of a matter of opinion and intended use. Of course larger cylinders will be slower, but will have more force. A larger pump will give more speed, but require more power and fuel.
Keep in mind that a towable backhoe is light, maneuverable, and cheap. You're not trying to compete with an excavator. You're competing with day laborers and shovels.
/ homebuilt backhoe #5
surpluscenter.com has pretty fair prices on valves, cylinders, and pumps - and they even have a "backhoe valve set" so you don;t have to gang up 2 way valves.
/ homebuilt backhoe #7
They can use up to 10 GPM at 4000 psi. I think, not sure.
/ homebuilt backhoe #8
I had a caddigger, 5 HP motor, 3 GPM pump, 2 inches except for boom which was 2-1/2. That thing dug like no tomorrow, I pulled huge rocks out of the ground.
I also like Surplus Center for hydraulic supplies.
Caddigger has plans as well as kits you can purchase.
Good luck,
Joel
/ homebuilt backhoe #9
Surplus center is good but if you check out EBAY search YZ outlet they have a lot of cylinders cheaper than SC. Just as good I use Prince myself but my first hoe was built using YZ cylinders and they were fine
/ homebuilt backhoe
Good luck,
Joel
the thing i was woundering was does it move vary fast :confused:
/ homebuilt backhoe
well heres the progres i have made so far i just have to get a fu more thing to finsh
heres a link to the video i made of the backhoe and if you want you can look at the video of my gator too YouTube - Towable Backhoe :D
thanks
welderboy14
/ homebuilt backhoe
heres a few pics:D
sorry have not post any pics for along time:eek:
_______________
welderboy14
/ homebuilt backhoe #14
Just thought of something. Everyone who owns a BH seems to wish he had a thumb. I know I do (and will build one sooner or later). You should incorporate that into your design.
/ homebuilt backhoe
o ya their will be thumb can't have a backhoe with out a thumb now can we:D
/ homebuilt backhoe #16
Couldn't tell from the photos - how does the hoe move side-to-side?
/ homebuilt backhoe #17
You're getting closer. I'm eager to see some shots of it in action.
/ homebuilt backhoe #18
Thanks for keeping us posted. That is a great project!
(Looks like a princess auto cylinder - is it?)
/ homebuilt backhoe
Thanks
yes thay are from princess auto (we will see how thay work)
7049CFL (A64553)
7049CFL (A64553)
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2012 Honda Civic Coupe (A64557)
2012 Honda Civic...
(UNUSED) HARDEE 28 BLADE DISC HARROW (A64278)
(UNUSED) HARDEE 28...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
