BEST COMPACT
/ BEST COMPACT #1
Kitz
anywhere usa
IH 244
HI IH GUYS IM LOOKING TO BUY A COMPACT TRACTOR I REALLY LIKE CASEIH AND WAS WONDERING WHAT YOUR THOUGHTS ARE LOOKING FOR A1980 OR NEWER 25 HP OR LOWER 3PT PTO NOT A SUBCOMPACT BUT SOMETHING WITH A LITTLE MORE WEIGHT THANKS AND ENJOY THE DAY
ANY HELP APPRECIATED
/ BEST COMPACT #2
THAT'S A LOADED QUESTION{WHY ARE WE SHOUTING}. Opinions will very just like with different types of soda pop. Get what you want {and is in the budget}. Some of us don't mind the gray market machines while others will jump all over the name. I'm happy with the one that runs and gets the job done.
/ BEST COMPACT #3
A common mistake is buying too small of a tractor.
Pick a brand that has dealer support near you for parts and service.
Last time I was in Keokuk, my wife dragged me out in the middle of a muddy field to dig up rocks geodes.
/ BEST COMPACT #4
I bought a used 03 DX35 and really like it. I'm glad I didn't go any smaller. I guess it's more of a compact instead of a sub-compact. I like having the extra weight. FWIW,I bought it in Pella,great dealer.
/ BEST COMPACT #5
Congratulations on your new tractor! If it has a loader, get the rear tires loaded if they are not already.
/ BEST COMPACT #6
I purchased a DX40 hydro with FEL in July, replacing a Deere 420 with bad hydros. A great tractor! I am doing a lot of FEL work as we're filling in a stock tank. One of the best features is the FEL uses the same quick-attach as a Bobcat or skid steer. I can switch between a bucket and pallet forks in about a minute. Transmission has a High-Neutral-Low selector lever, and then a high-low switch within each range. The switch is on the right fender, but also on the FEL joystick, so you can switch ranges without moving your hands. Tilt steering wheel, swiveling seat, plenty of power, I really like this tractor. My Case dealer was very easy to deal with, and fixed one minor problem (hydraulic leak) in my pasture. An advantage of dealing with someone who supports construction equipment!
Negatives: There are 4 filters that need replacing (oil, fuel, hydro, and steering) and they are ALL hard to get at. Get a set of the slip-on filter caps you can turn with a socket wrench, or a vertical strap wrench. A standard band-type filter wrench is useless. My 50-hour cost me $85 in filters - should have had the dealer throw in the first set. The FEL does not come standard with a front guard; see if you dealer will throw it in (mine did). Definitely fill the back tires - the ride is too bouncy and heavy loader work will tip it without filled tires.
Bottom line: I paid no more for a 40-hp Case/Farmall than quotes for a 32-hp Deere or Kubota. Spent 10 hours on it one day and felt great. Haven't found anything it won't do.
/ BEST COMPACT #7
I agree with getting a brush guard. Back in June I bought a dx45 with a FEL. I had the back tire filled with beat juice. It cost me 160 at the dealer worth ever penny.
I have not run out of power yet. I have a 6 tiller used it in soil with rock large rocks with roots with no problems.
About the brush guard about a month ago I ran a tree though my headlight assembly when trying to dump brush on top of a pile. The new assembly cost me 170 at the dealer. Not a good way to start out with a new tractor.
As far as price I only paid 21k out the door with everything.
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
(INOP) 2008 FORD F150 XL TRITON TRUCK (A59823)
(INOP) 2008 FORD...
2005 Bobcat 435 (A60462)
2005 Bobcat 435...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
