5303 rockshaft problems
/ 5303 rockshaft problems #1
Red Q Neck
I have a JD 5303 w/512 front end. My rockshaft will not lower no matter what I do. This is the second time this has happened. The first it was under warranty and I did not pay attention to what was done to fix the problem but from what I understand there is a valve that sticks and has to be cleaned.
My question is, is this something I could do my self? Is this valve the same one that is under the seat that locks the shaft?
Any help in this matter would be greatly appreciated
Red
/ 5303 rockshaft problems #2
Red
Welcome to TBN:D
Yeah, it's the ROD (Rate of Drop) valve under the seat that gets clogged up. Fairly easy to R&R it. You can log in to JDParts.com and/or get a service manual to help out.
/ 5303 rockshaft problems #3
Red, if I remember right, it's the main 3pt hitch control valve located under the rockshaft housing. Pretty big job for home.
Thanks guys, I'll give the R.O.D. a shot...
Red
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2020 Komatsu PC210LC-11 Hydraulic Excavator (A66734)
2020 Komatsu...
