Question about Google Earth "elev" and perpendicular
/ Question about Google Earth "elev" and perpendicular #1
allenr
Gold Member
Barossa Valley, South Australia
Duetz DX3.70, Fendt 305LSA,260S & 205P,Kubota B6100E & 3 x B5100E & RTV900, Caterpillar 428C
I hope somebody with more Google Earth knowledge can help me.
Can I discover the low and high points of my land by looking at the "elev" "ft" number at the bottom - middle of the picture?
Oddly the higher ground seems to have a higher number, yet given that the "eye alt ft" number remains the same shouldn't the higher ground have a lesser number?
Or is the "elev ft" referring to elevation above sea level.
Is the elevation figure accurate enough to guide me as to where the start and end point of a drip hose of say 200m (660ft) should be to minimize the friction loss over that length?
And how can I know when I'm perpendicular (directly above ) my land?
/ Question about Google Earth "elev" and perpendicular #2
Google earth is not designed to be that accurate. The cheapest way to do this is with a transit. You can buy a simple one for less than $100 on ebait
Typical elevations are shot from a ref mark. Above sea level is a ref. Above or below the becnmark at the center of the propery. Then they are exspressed above or below.
/ Question about Google Earth "elev" and perpendicular #3
If you or someone you know has a good gps it will show elevations. I use an old fashion topo map. It has 20' elevation lines. Different areas show different lines.
/ Question about Google Earth "elev" and perpendicular #4
Does your local or "federal" government have topographic maps?
Before this Internet thingy :D I used to get topographic maps for land I was looking to buy. They have elevation marked on the map. In the Internet Age my rural county has a GIS aka mapping office that is online. They show property lines, topographic maps and even areal photos overlayed on the property lines.
I know the UK made VERY accurate surveys decades/century ago. I think they were called ordinance surveys. Maybe the same happened in Australia.
Later,
Dan
/ Question about Google Earth "elev" and perpendicular #5
You can do it with Google Earth with the add on to make it a topo map
below is my land
Sorry I see your down under so I don't know if it will work as mine is for the lower 48 states. They also call it Trail maker software for hiking.
Thanks guys, for the information.
I'll check into the options suggested.
Kwin, what do you mean by "Florida soon Texas?
/ Question about Google Earth "elev" and perpendicular #7
The alt eye elevation is the elevation that your looking from (the airplane) and it doesn't change when you move the cursor around the screen. Teh elev ft (or meters) is generally ft above sea level depending on your settings. The alt eye elevation is also MSL but should not effect your search for high and low points.
P.S. I would have to agree with the other posters that google earth is great for a lot of stuff but it isn't always that precise. Its great to find the general area, or if something will generally work but I would definatally take additional measurments (gps, etc) before actually building something.
/ Question about Google Earth "elev" and perpendicular #8
I have a very good handheld GPS and it will only give about +/- 25 ft (say 8 m) on the best of days for elevation, and many days it is about twice that.
However, the best GPS units have a built in barometric altimeter which will be able to measure differences, which is what you are concerned with to about a meter, if you learn how to calibrate them.
Since you already have the line and a water source, with a transparent section at one end and a large reservoir at the other, you could easily make a water level, and measure differences in elevation to a few mm over 200 meters.
Yes, I have done that in the past, very accurate, just looking for something quicker - and easier.
But to everybody, how do I now when I'm perpendicular (directly above) - and does that add to the inaccuracy of the elevation figure?
Later,
Dan
Yes I believe we have all of the above, but the governments don't do anything for nothing!
/ Question about Google Earth "elev" and perpendicular #11
Well yes we pay for it but I can go online and find my property lines, matching topo maps and areal photos for no fees. Or I can go to the GIS office and either use the PC there or get some big huge maps to look at for no charge. If I want a print out I can get it for a nominal charge that fairly covers the costs of a big piece of paper and the printer that can print on that paper.
Now my local government but in this case they charge nothing or a fair amount. The last time I bought a print out from them it was $5 for a paper about 24"x36".
Getting a topo map from the US government is not that hard or expensive either. I think I can do it online now and there are stores I used to be able to buy from as well. Though this market seems to be drying up as people move to GPSes.
Later,
Dan
/ Question about Google Earth "elev" and perpendicular #12
Kwin, what do you mean by "Florida soon Texas?[/QUOTE]
It is time to retire to my small place around Lake Limestone in Texas. Cost of living is gone nuts here in Fl. plus my kids, grandkids are in Texas.
I also lived in Houston for 30 years.
Dan
To the best of my knowledge none of what you refer to is available online in Australia. You've got to buy it at the relevant office and expect to pay $50 plus.
With the possible exception of local gov, most state and federal gov websites are fairly useless. Either they simply don't offer online services or when they do they're often impossible to negotiate.
I tried a while back to set up an account to pay my tax online but eventually had to give up.
/ Question about Google Earth "elev" and perpendicular #14
don't know if it will help but I found this on topo maps plus they also have walk-about-maps!!!:)
The catalogue describes items held in the Library's collections. You can request or reserve the items for use inside the Library building in Canberra by becoming a registered user. If you can't visit the Library, you may also be able to order a photocopy or photograph of an item through our Copies Direct service, or you can ask your local library to borrow an item on your behalf. Further details about using our collections are available on our website.
Thanks Ken.
Hope your move to Texas goes well.
Is there a particular website url I should look for?
/ Question about Google Earth "elev" and perpendicular #16
You might try dropping by your local Military, Government Land office etc, as we used to call them "Army Maps",..deadly accurate. With todays computerized and GPS etc,...those old paper maps may be gathering dust. They likely give you a bunch. I have them for my area,..extremely helpful !! Easy to read.
Good luck Allen,
. . tug
PS: . . OOops sorry Allen,..I just now saw your item about the $50. fee for stuff. Wouldn't hurt to drop by and "ask" for a map, . . .....would it?
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
Unused 2021 Paladin QH1 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2021...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
